Upgrading dash on 09
Old Jan 15, 2018 | 11:24 AM
Scottfreidel's Avatar
Scottfreidel
Hey everybody. New to the forum but wanted to see if anybody can give me some advice before I buy a g37s. The year is 2009 and its a manual sedan. Kinda pissed off they didn't make the q50 as a manual cause I really like the improved dash with the 2nd screen. So my question is: can you replace and upgrade the existing dash with the clock to the screen in the q50s? Thanks in advance.
Old Jan 15, 2018 | 12:09 PM
canucklehead's Avatar
canucklehead
nothing is impossible, but certainly some things are impractical. replacing the G37 dash with a q50 dash would be a good example. can it be done? probably, given enough time and money. that said, i wouldn't recommend it. the amount of wiring and electrical/dash fabrication required would be considerable. once you found a shop willing to do it, be prepared for a blank cheque and open timeline approach.
i hear you with the frustration of Infiniti dropping the 6MT option post-G37, but you'll either have to live with the dash G37 as-is, live with the q50 as-is, or look for something else.
Old Jan 15, 2018 | 12:42 PM
dkmura's Avatar
dkmura
20 Year Member
The answer is NO- swapping over a dash from model to another would likely exceed the cost of the car itself. The electronics would be a nightmarish to retrofit and are not a plug n play feature.
Old Jan 15, 2018 | 02:25 PM
qmantran's Avatar
qmantran
Where's the /palmface emoji?
Old Jan 15, 2018 | 04:26 PM
ryanwhite74115's Avatar
ryanwhite74115
DO IT!!!! Youtube the process!
juliengc
Jan 15, 2018 01:57 PM
