signal bulbs location
Old Jul 30, 2017 | 02:32 PM
drrush0407's Avatar
drrush0407
2012 infinity g37 where are the bulbs located to be changed out?
Old Jul 31, 2017 | 01:00 PM
Entcee's Avatar
Entcee
Assuming you mean the front turn signals, one of the easiest ways is to go through the wheel well. Removing the tire will give you more room to work, but not 100% needed.
Old Aug 4, 2017 | 02:53 PM
g37x2013's Avatar
g37x2013
You can go directly to both front turn signal bulb from the engine bay without removing a thing, I have a 2013 g37x, not sure if the setup is the exact same though. I have swapped mine out several times without moving a single thing going from the engine bay.
Old Aug 5, 2017 | 06:20 PM
G37xS-Life's Avatar
G37xS-Life
Is it the same for a coupe and a sedan?
Old Aug 5, 2017 | 06:25 PM
g37x2013's Avatar
g37x2013
I am not sure of that.
Old Sep 6, 2017 | 03:06 PM
hozilla's Avatar
hozilla
I have a 2013 sedan and I swapped these bulbs out last weekend. For the 2013, I don't think it's possible to access it from the wheel well?
Instead, I went under the hood and removed both air filters. Just need to unbolt it and loosen the clamp and slide it up.
FYI*The turn signal and parking light are the same for the 2013 models, in case it differs from the '12.
Old Sep 6, 2017 | 05:57 PM
Surfnazi's Avatar
Surfnazi
Go through wheel well or remove light housing
Diode Dynamics
Lighting/Cleaning Products
40
Nov 30, 2021 02:30 PM
ONEighty
38
Feb 28, 2019 04:59 PM
IrishMike
Jan 12, 2017 01:48 PM
G-unOt
Sep 27, 2016 03:52 PM
