Fix window issue
Old Jun 23, 2017 | 11:40 PM
Gtrlos's Avatar
Gtrlos
Fix window issue
My window didn't roll up all of a sudden. I tired resetting but no luck. I've found no tutorial on how to fix it. What do I do? It's been completely open for the past day and I stress over my belongings. Please help!
I can't seem to push it up either
Old Jun 24, 2017 | 12:32 AM
UCLAG37's Avatar
UCLAG37
Before you took the panel off, what happened to the window when you hit the switch up or down? Any noise from the motor? Window move? Did you check fuses and relays? Did you have the key in the "on" position?
Most common issues from my experience are:
1. bad relay or fuse
2. bad window motor
3. bad regulator
4. loose connection/short
5. bad switch
6. window unbolted from the regulator frame and jammed up
If you have a Power Probe, you can diagnose the problem in minutes.
UCLAg37
Old Jun 24, 2017 | 01:08 AM
Gtrlos's Avatar
Gtrlos
There is no noise coming from the motor even when the car is on
Old Jun 24, 2017 | 02:03 AM
crookncastle's Avatar
crookncastle
assuming you already checked the fuses, test to see if you have power at the window motor connector when you operate it. if there is voltage in both the up and down position pull the motor off the window regulator spool gear and ck the motor operation with it detached from the regulator. if motor works then its a problem with the regulator.
Old Jun 25, 2017 | 01:19 AM
mummy2's Avatar
mummy2
Try this. It worked for me twice. https://www.myg37.com/forums/g37-cou...ndow-fuse.html
