Help connecting Daytime Running Lights
Old Jan 8, 2017 | 11:40 PM
DrizzyDrake1's Avatar
DrizzyDrake1
I have a 2008 g37 coupe, I am thinking about adding some light strips behind the bottom grill. I just want to know what slot the ACC is located in to be able to have the lights on at all times while the car is on. I realize that this might stir up some emotions about whether this will look good on a G but I've seen it, and mine will be a tasteful addition, nothing crazy. I just need to know how to connect the lights since I don't have an ACC tester or whatever, so the exact slot where to plug them in would be appreciated. Thanks guys.
Old Jan 9, 2017 | 06:35 AM
Elco's Avatar
Elco
I connected the DRL to ACC line from the electric panel on the cabil, lower left side, under the fuse box. It was a PITA to pass the wire from the engine bay into the cabin, but once that was done, the rest was easy. There are 2 thick blue wiress on the connector on the lower part of the electric panel.
Old Jan 9, 2017 | 07:53 AM
DrizzyDrake1
Do you have any pics of that connection?
