2008 Infiniti G37S Coupe MAJOR WINDOW ISSUE
Old Nov 6, 2016 | 06:39 PM
Mrfudge's Avatar
Mrfudge
Been having this issue since I've had my car, window doesn't roll down.
Here are the symptoms: doesn't roll down when you press the window button, when it does roll down, 100% chance it won't roll up, so it's stuck in the up position, however it does roll down the inch when you open the door but will not roll up when you close the door, will roll up when the car is on. One last note, the feature where if you hold down the unlock button on the key fob to roll down the window, the window also rolls up once the car is turned on.
I have replaced the window regulator, and I tried changing out the window switch
With used ones, the first one nothing worked , the second one had the same symptoms the current did.
PASSENGER WINDOW WORKS PERFECTLY JUST THE DRIVER WINDOW
WHAT AM I MISSING?
ANY SUGGESTIONS
Old Nov 7, 2016 | 06:15 PM
telcoman's Avatar
telcoman
WHAT AM I MISSING?
ANY SUGGESTIONS
Have you tried the FSM?
Factory Service Manuals - NICO Club
Telcoman
Old Nov 7, 2016 | 06:56 PM
rsingerG37's Avatar
rsingerG37
Motor and/or motor reset?
Old Nov 7, 2016 | 07:52 PM
Mrfudge's Avatar
Mrfudge
So there's a separate reset procedure than the window switch
Old Nov 7, 2016 | 09:09 PM
saywat?'s Avatar
saywat?
op said he replaced the regulator. people still calling the motor the regulator? bc to me the regulator is the window frame part with the cables. with that said sounds like u gotta replace the motor. if u did wat did u go with?
Old Nov 8, 2016 | 06:51 AM
Mrfudge's Avatar
Mrfudge
Sadly enough I'm at the point where I might have to to take it to the stealership and have them look at it
Old Nov 30, 2016 | 06:38 AM
FazzG37's Avatar
FazzG37
WHAT AM I MISSING?
ANY SUGGESTIONS
maybe it had to do with the battery being disconnected. Once I changed my battery the windows wont roll up when i close the door so it closes the gap (it automatically goes down slightly when you open the door). and when i open the door they wont roll up at all. By closing the door and pulling the windows down fully, then rolling back up all the way but kept on holding it for a couple more seconds and then let go and pressed the button again to roll them up. It seemed to do the trick for my car. Not really relevant to your case but Hope this helps a bit. Apparently it resets some sort of fuse or something idk.
Old Nov 30, 2016 | 05:23 PM
Kris9884's Avatar
Kris9884
Lol dramatic much? "MAJOR WINDOW ISSUE!" means you're stranded on the side of the road with the window motor catching on fire or all of your windows were busted out by the stock subwoofer or something lol.. Just breath... Then search and fix the issue..
