Analog clock light flickering
Old Jun 24, 2016 | 12:17 PM
Ihtbealexxx's Avatar
Ihtbealexxx
My analog clock recently started flickering. Happens rapidly after the first start of the night and then happens intermittently once I drive around for a bit. All other lights and gauges work fine, so I don't think it's a battery issue.
Is there a way to replace the LED in the clock or would I need an entirely new one? How much would it cost if anyone knows as well?
Old Jun 24, 2016 | 01:04 PM
iCrap's Avatar
iCrap
If you are pretty handy with soldering you can likely take it apart and replace the LED.
Although, LEDs don't really go bad that often so its possible something else is causing the flickering.
Old Jun 24, 2016 | 04:44 PM
guy from norcal's Avatar
guy from norcal
If its under warranty the dealer will replace it.
Old Jun 24, 2016 | 04:53 PM
the_wolff's Avatar
the_wolff
I had mine replaced under warranty. They replaced the whole clock, so I'm not sure if just the light can be fixed, or if it just isn't worth their time.
Old Jun 25, 2016 | 10:59 AM
Ihtbealexxx
I'm not under warranty anymore, sadly
Old Jun 25, 2016 | 01:56 PM
SomeName's Avatar
SomeName
I think this is a pretty common problem. Mine was warrantied as well. I was driving from AZ to NY and it just started blinking at about 2am. I didn't even know it was supposed to light up. Freaked me out. Anyways, it took the dealer about five minutes to swap it out so I assume its not that hard.
Old Jun 25, 2016 | 04:18 PM
ctyke's Avatar
ctyke
Yeah I had the same problem, and it eventually went out. Mine was under warranty, so I just paid the $50 deductible and they replaced the whole clock. Unfortunately this is the only official fix - its $600 Not sure if you can do it yourself but it can't hurt to try.
Old Oct 4, 2016 | 12:13 PM
EuroRSN's Avatar
EuroRSN
Cant believe its so expensive. Wish they had a replaceable bulb like they did in the first gen g35s. Oh well..
Old Oct 4, 2016 | 04:56 PM
Frob91's Avatar
Frob91
Mine is completely off and I'm looking for a way to fix it, if someone knows...
Thanks guys
Old Oct 4, 2016 | 05:28 PM
EG Ryan's Avatar
EG Ryan
See this thread:
https://www.myg37.com/forums/g37-sed...ock-light.html
There apparently is an updated clock (part number 25810-1ca1b) which addresses the lighting issue.
Old Oct 4, 2016 | 06:53 PM
Crazyirish's Avatar
Crazyirish
Originally Posted by EG Ryan
See this thread:
For a mere $300 apparently...
Old Oct 5, 2016 | 02:42 AM
Elco's Avatar
Elco
If the clock use LED for light and is powered by 12V, then it must use some LED constant current driver circuit.
LED's don't go bad or burn up. Most likely the driver is the fault.
It should be easy to repair or replace the driver circuit with a different one from some aftermarket LED bulb.
If it use some incandescent bulb, just replace the bulb and call it a day.
Old Oct 6, 2016 | 05:31 PM
Ihtbealexxx
300 dollars for a clock I barely look at. No thanks LOL. Just gonna look for a used one via part outs
JJETIPL
Apr 7, 2017 03:18 PM
samkon
Jul 25, 2016 08:19 AM
baysurfer
Northern California
May 26, 2016 04:26 AM
Tuguacshayan
Apr 28, 2016 12:21 AM
SonicVQ
Mar 31, 2016 04:20 PM
