OEM headlight bulbs wearing out? Good replacement?
Old Feb 24, 2016 | 09:17 PM
iCrap's Avatar
iCrap
Seems like my OE bulbs are getting pretty dim.. is this even a thing with HIDs? I don't really remember if they used to be brighter, but i can hardly see a damn thing now. Today there was a really bad rainstorm and it was sketchy as hell in the pitch black.
Now, as for changing them... Can you just swap in a new bulb? Or do you need to replace the ballast as well? Get OEM bulbs or are there a better alternative?
Old Feb 24, 2016 | 09:32 PM
Vicious37x's Avatar
Vicious37x
You can swap in new compatible bulbs.Have you tried cleaning the headlight bulbs? There should be a DIY on this site.
Old Feb 24, 2016 | 11:33 PM
iCrap's Avatar
iCrap
cleaning the bulbs? no I didn't even know you were supposed to do that. My actual headlight lenses seem to be clear though. No haziness.
Old Feb 25, 2016 | 03:21 AM
salmonslayer's Avatar
salmonslayer
I buy bulbs for my cars from the retrofit source. https://www.theretrofitsource.com/co...ts/bulbs.html/
Old Feb 25, 2016 | 07:49 AM
PongSanity's Avatar
PongSanity
diode dynamics....
Old Feb 25, 2016 | 08:24 AM
main_shoby's Avatar
main_shoby
Originally Posted by PongSanity
diode dynamics....
Diode dynamics switch back leds with resistors
Old Feb 25, 2016 | 09:44 AM
Ricio1991's Avatar
Ricio1991
Morimoto xb35 D2S bulbs from theretrofitsource.com
Hands down one of the best aftermarket bulbs out there
Old Feb 25, 2016 | 10:10 AM
SonicVQ's Avatar
SonicVQ
No need to clean the HID bulb. It can't get dirty as it is almost 100% sealed inside the headlight assembly. Generally when HID bulbs are starting to go, they will have a red tint when looking at them.
With the age of your car, I suspect they need to be replaced. Your ballasts do not need to be replaced.
Old Feb 25, 2016 | 12:08 PM
iCrap's Avatar
iCrap
diode dynamics....
Well those are LEDs right... Not HID headlights?
This is what I was thinking.. The car is nearly 9 years old so it wouldn't surprise me if they are going bad. They don't look redish but they seem to project a more amber light, not the super bright white i expect from a HID.
Is it this?
https://www.theretrofitsource.com/mo...ght-bulbs.html
And that'll work on the OE ballast?
Also, found this. Which seem to just be OE bulbs but i'd like to get the brighter / better morimotto if its direct fit.
D2S AGT HID Bulb 85122C1 [D2S-PH-] - $29.95 : Philips Xenon HID Lights Bulbs Ballasts Kits
Old Feb 25, 2016 | 12:12 PM
Ricio1991's Avatar
Ricio1991
Well those are LEDs right... Not HID headlights?This is what I was thinking.. The car is nearly 9 years old so it wouldn't surprise me if they are going bad. They don't look redish but they seem to project a more amber light, not the super bright white i expect from a HID.Is it this?
Nope this is what you need! The g37 headlight bulbs are hids, they come in 4500k, 5500k, 6500k. The color chart is on the page I showed you, I would say go with 5500k or 6500k
https://www.theretrofitsource.com/co...l#.Vs81tEVHanM
Old Feb 25, 2016 | 12:13 PM
Ricio1991's Avatar
Ricio1991
Also yes these will work with the oem ballast plug and play nothing else required
Old Feb 25, 2016 | 12:55 PM
iCrap's Avatar
iCrap
Awesome, i'll probably get those then. Might pick up some new fog bulbs while im at it.
Old Feb 25, 2016 | 01:59 PM
bri's Avatar
bri
I wonder how legit this website is. They use the Philips name but does not to be truly associated with the manufacturer. Those Ultinon bulbs are $30 (each?) while Retrofitsource sells them for $175 a set.
I have the "famous" Osram CBI's 5500k and am unfortunately not that impressed. They are closer to the stock "tinge of yellow" than a true white or even having any "tinge of blue" at all. There is a touch of blue on startup but it changes pretty drastically once warmed up.
Someone else posted that they got these:
http://www.ebay.com/itm/171652670727?var=470627939178Which is what I might try to get closer to 6000k color
Old Feb 25, 2016 | 02:19 PM
Ricio1991's Avatar
Ricio1991
What year is your g? Fog lights in headlight or in the bumper?
Old Feb 25, 2016 | 03:44 PM
iCrap's Avatar
iCrap
New Genuine Onyx HID Xenon Pair D2S D2R for OSRAM or Philips Headlight Bulbs | eBay
Those seem waaayyy to cheap to be legit
07. They are in the headlight.
