Passenger Window/Door Lock Switches Not Working... Again
Old Jan 18, 2016 | 03:16 PM
SpeedBallDEVIL's Avatar
SpeedBallDEVIL
I had my car tinted and then a few weeks later the passenger window wouldn't respond to the switch on both driver and passenger side. The Passenger side door lock switch was also unresponsive. The window also didn't shim up or down when the door closes and opens.
Brought it to Infiniti, they said the pass door switch came disconnected. They reconnected it and I sent the bill to the tint shop.
Now a few months have gone by and my pass door switches are unresponsive again.. I guess the switch fell out again?
Does this happen to anyone else? I'm gonna take the door panel off and just try reconnecting it but this is kinda ridiculous...
Old Jan 18, 2016 | 03:19 PM
2008G-Man's Avatar
2008G-Man
my guess the "clip" or "catch" that holds the connectors together never got fully engaged and/or it's broke.
Old Jan 18, 2016 | 03:53 PM
SpeedBallDEVIL
Just wasn't sure if this was a common issue or not. I guess I will just electrical tape it.
Old Jan 18, 2016 | 05:09 PM
2008G-Man's Avatar
2008G-Man
That's what I was going to suggest, or wire tie it together. Haven't heard of this on the forum, good luck.
Old Jan 19, 2016 | 12:16 AM
SpeedBallDEVIL
So interestingly enough, the passenger window switch works now. I didn't tamper with it at all.
Any suggestions here?
Old Jan 19, 2016 | 08:29 AM
2008G-Man's Avatar
2008G-Man
Water, loose connection, switch going bad .... intermintant problems are the worst. I would pop the door panel and take a look, reseat everything and make sure all connections are tight and will stay that way.
max223
Dec 14, 2025 04:45 AM
iCrap
22
Jan 5, 2020 04:02 PM
delfinparis
Jan 17, 2016 11:39 AM
iCrap
Jan 16, 2016 10:57 PM
