Restored my headlights
So I did the DIY headlight restoration since I had some oxidization in my headlights and completed the driver side and came out good. Did it on the passenger side and waxed it and everything but I can't get rid of the cloudiness on it now. Should I try the entire process again or should I just keep waxing it with the drill?
Blue Magic Headlight Lens Sealer, 236 ml 730 | Zoro.com
Glad it worked out, might want to use this to keep them fresh
I've been using the Turtle wax headlight restore, following the exact directions, and buffing with a drill attachment. However, they are still coming out quite cloudy. I've gone over it a few times starting from the very beginning of the process and buffing multiple times as well, but I cant seem to get rid of the haze. I honestly cant figure out what the F I'm doing wrong! Considering so, the directions say to change directions of wet sanding by 90 degrees, in which I'm doing so, but does changing the direction really make that much of a difference or should I stick with the same sanding direction throughout? Thanks!
https://www.myg37.com/forums/d-i-y-i...storation.html
I can attest that the only method to truly get them clear is wet sanding the headlights to even out the plastic and remove and scars and then buffing the hell out of them. Seal them with wax or a sealant and they'll be good for around a year.
Unfortunately when you sand them you remove the UV coating and they're prone to fogging up more easily. So it's really a maintenance thing you have to keep doing to keep them looking nice.
Oh really? So I need to sand a little deeper then basically? It seemed to me that by sanding deeper would only make it worse? I have the sand paper, rubbing compound and wax, so ill re attempt it this weekend!
It will look AWFUL at this stage but be smooth. They will look super fogged up and worse than when you started. At this point you need to buff and buff with polishing compound until they become clear again.
Then seal them.
