Help iron man running as del wiring
Old Nov 12, 2014 | 08:40 PM
REDg37vx2's Avatar
REDg37vx2
i wanna install iron man leds onto my g37 coupe and wanted them to run as my drl lights. how would i go about wiring this mod? i don't want a extra switch installed in my cabin, i wanna install it in a way that when i switch my light switch (where the steering wheel is) to the drl setting the iron man leds will pop on. i know ill have to splice the pigtails and I'm fine with that just can someone guide me as to what wire i have to splice?
Old Nov 15, 2014 | 09:47 AM
Twista's Avatar
Twista
U have a drl switch???
Old Nov 16, 2014 | 03:03 PM
REDg37vx2's Avatar
REDg37vx2
I meant city lights sorry
Old Nov 16, 2014 | 07:59 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
Get some T taps and tap into your parking lights if you want them to turn in with the parking lights. Personally, I tapped into my windshield reservoir so that my halos are on whenever the ignition is set to ON.
Old Nov 17, 2014 | 07:41 AM
REDg37vx2's Avatar
REDg37vx2
Yea but how do I wire all the wires into one wire? For example look I have 10 LEDs going on one shroud. Each led has two wires (red and black) that makes it 20 wires on one headlight. I have to splices 20 wires into one wire?
Old Nov 17, 2014 | 10:10 AM
ttv36's Avatar
ttv36
^ I would either a) solder or crimp them all together or b) get a fused distribution block for them. B would probably be the proper way of doing things.
Old Nov 17, 2014 | 01:07 PM
REDg37vx2's Avatar
REDg37vx2
Where can I get a fused distribution box ?
Old Nov 17, 2014 | 02:52 PM
REDg37vx2's Avatar
REDg37vx2
there are 3 wires in the parking light, which one would i tap into?
Old Nov 17, 2014 | 03:37 PM
2008G-Man's Avatar
2008G-Man
Dude ... sounds like you are not technically up to doing this work. You need to understand basic DC Electricity and have a volt meter.
Old Nov 17, 2014 | 04:53 PM
REDg37vx2's Avatar
REDg37vx2
I never said I was "technically" ready to do it. That's why I'm asking for help so I could be "technically" ready for it. All I'm asking for is which wire do I connect to which? I know the led has two wires, one that's black and one that's red (a positive and a negative.) I also know that the parking light has three wires, a white one, a green and white, and a green and black. I know the white wire is ground and one of the green ones is the parking light and the other one is a positive or something like that. We all start from not knowing **** but we learn. And that's what I'm trying to do. So instead of telling me I can't do it, help me better understand this.
Old Nov 17, 2014 | 05:46 PM
2008G-Man's Avatar
2008G-Man
I don't know Spanish but I do know I would never attempt to learn it by asking people questions here and there. Doing Iron Man LED headlights should be left to the experts. Just taking your headlight assembly apart correctly (and putting back together) is a very difficult task to do right. I was pointing out this seem's to be out of your league but if you want to plunge ahead got for it. I'll wait for the post where you say your headlights leak and they don't work, etc.
Old Nov 17, 2014 | 05:59 PM
REDg37vx2's Avatar
REDg37vx2
I took my headlights apart over 3 months ago, painted them and sealed em back up and till this day no leaks or anything....just because you don't feel like expanding your knowledge doesn't mean others aren't willing to...
Old Nov 18, 2014 | 12:19 PM
2008G-Man's Avatar
2008G-Man
Good luck then.
ZSpeedPerformance
Drivetrain
12
Sep 9, 2016 11:20 AM
Upscale Speed
Oct 9, 2015 01:42 PM
deod
Southern California
Sep 15, 2015 08:12 PM
RexHavoc
Sep 6, 2015 01:03 AM
