my new headlights...by me
Old Jul 25, 2014 | 02:40 PM
REDg37vx2's Avatar
REDg37vx2
Yea it's the same exact process just only I baked for 7 minutes at 190 degrees. And I also baked when closed everything up. I work at a factory that makes insulated glass units so we have this special glue we use to make sure the unit doesn't fog up. I took some home and applied it. Rained about 2 times since and nothing got inside. Keeping my fingers crossed nothing will happen later on down the road.
Old Jul 25, 2014 | 02:58 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Looks nice! Should have done a clear lens conversion while you were in there to eliminate the Fresnel lens. I want to open up the lights and do a clear lens swap and DRLs but these headlights are so expensive to replace, it makes me nervous. I'm not exactly a noob either when it comes to this since I did a halogen to projector retrofit, with CCFL angel eyes and paint on my previous car. Thanks for posting, this is definitely encouragement to take the risk.
Here is a brief look at the work I did that I referred to above:
Old Jul 25, 2014 | 04:40 PM
REDg37vx2's Avatar
REDg37vx2
You know honestly I def suggest going for it. I was also very worried about it at first because I knew both headlights would run me about 1k to replace. There's a saying those who don't risk don't drink champaign. Go for it man. Looks like you did a very nice job on the previous car. Just take your time and don't rush.
I actually ordered the lens with te angel eyes. Should be getting it in 2 weeks so I'll be re opening it
Old Jul 25, 2014 | 07:49 PM
Ryne's Avatar
Ryne
Good call!
Old Jul 25, 2014 | 08:06 PM
Originally Posted by Ryne
Good call!
Yep, I try to yell from the rafters whenever someone want to DIY their lights, the lens swap is almost a dramatic as the painted housing.
Just do it Ryne, you'll do just fine, just be sure to use the butyl sealing tape when you button them back up, much better than RV silicone.
Old Jul 26, 2014 | 03:42 PM
guy from norcal's Avatar
guy from norcal
very cool, looks agressive
Old Jul 26, 2014 | 04:33 PM
Ryne's Avatar
Ryne
I'm a huge fan of TheRetroFitSource, so I would probably buy their butyl rope. It's been almost two years since I've cracked open headlights, but I'm sure it wouldn't be out of my DIY capabilities. I have to figure out what style DRL I want and what parts I would need to get for the job.
Keep us posted with some pics are the lens swap and DRL upgrade!
Old Jul 26, 2014 | 07:16 PM
REDg37vx2's Avatar
REDg37vx2
Will do sir. I just spent 8 hours detailing my car(clay bar, swirl x, polish, and waxed). Wrist is killing me but the result is worth the pain. Truly is.
Old Jul 26, 2014 | 09:59 PM
Awesome, sounds like your G found a good home
