Broke tabs in headlight
Old Jun 26, 2014 | 06:20 AM
grojas112's Avatar
grojas112
Hey guys, earlier this week i replaced the halogen bulbs with LEDs. I also replaced the stock d2s bulbs with the Osram CBI 5K. While changing the d2s bulb I accidentally broke the clips that hold the retainer in place. Without the tabs the bulb moves around in the housing.
How can I secure the bulbs from moving around in the housing without purchasing a new headlight.
Thanks
Old Jun 26, 2014 | 08:19 AM
telcoman's Avatar
telcoman
Duct tape!
Telcoman
Old Jun 26, 2014 | 08:26 AM
chilibowl's Avatar
chilibowl
Thanks
What method of access did you use to replace the bulb?
Old Jun 26, 2014 | 08:28 AM
grojas112's Avatar
grojas112
I originally tried removing the bulb from behind the bumper. I broke the tabs due to the lack of visibility. I then removed the bumper and the headlight and got to it. it was too late at that point.
Old Jun 26, 2014 | 08:52 AM
chilibowl's Avatar
chilibowl
Didnt I specify to you, to remove the wheel? It literally takes 10 minutes to remove a wheel. Had you taken my advice....You wouldnt be in this predicament homie.....
Old Jun 26, 2014 | 09:19 AM
warped ideas's Avatar
warped ideas
A quarter past stripped
Originally Posted by telcoman
Duct tape!
Telcoman
If you can't Duct it, f^ck it! But in all seriousness, you may be screwed. Now is a good time for new headlights done up by 180.
Old Jun 26, 2014 | 11:20 AM
grojas112's Avatar
grojas112
If i purchase i used G37 projector on ebay. Will I be able to swap out the retainer and clip.
Old Jun 26, 2014 | 11:59 AM
chilibowl's Avatar
chilibowl
Yes, just make sure the projector you buy, you can visually see the retainer clip attached.
You will have to remove the entire headlight assembly to comfortably work on it and take your time.
Old Jun 26, 2014 | 12:50 PM
Detail's Avatar
Detail
The retrofit source may have just the retainer clip you are looking for. Call them.
Old Jun 26, 2014 | 12:57 PM
grojas112's Avatar
grojas112
Thanks guys
Old Jul 8, 2014 | 08:33 PM
transportchef's Avatar
transportchef
Hey grojas112 what part no did you order? I am in the same boat as you.
2K1 6T8
Oct 6, 2015 07:40 PM
EnYcee-G
Oct 4, 2015 09:27 PM
Allboutcali
Sep 26, 2015 03:43 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
