Lumen Lights ?
Old May 22, 2014 | 10:30 AM
ANMVQ's Avatar
ANMVQ
Lumen Lights ?
So I got a gift card(wife) from CARID. I bought LED turns , reverse and front markers from them they sell Lumen LED's? We pricey, Like $22 each but they say there is no need for a resistor or anything for the turn signals?
LUMEN ERROR FREE:
Replacing factory halogen bulbs with some brands of LEDs can cause "bulb out" error messages, sporadic operation, and generate system faults that activate check engine lights. Because all bulbs in most modern vehicles are controlled by a single module that is in series with other control computers, something as simple as an improperly designed bulb can break the normal loop of data communication that tells your main engine controller all systems are go. Lumen bulbs are CAN Bus compatible, and have been designed with a higher level of advanced technology that allows proper data flow - so they'll work right every time without error messages, and without confusing any computer controls.
Old May 22, 2014 | 11:05 AM
connoisseurr's Avatar
connoisseurr
Post a link?
Old May 22, 2014 | 11:21 AM
ANMVQ's Avatar
ANMVQ
here ,I got the PLAZMA ones
http://www.carid.com/2009-infiniti-g...-10273764.html
Old May 22, 2014 | 11:51 AM
socialconflicts's Avatar
socialconflicts
so they wont hyper blink?
Old May 22, 2014 | 12:09 PM
ANMVQ's Avatar
ANMVQ
They say they wont! For 22$ a bulb they better not,
Old May 22, 2014 | 12:16 PM
ANMVQ's Avatar
ANMVQ
Just got an email. I will have them today when I get home, Hope to get them in and get some night shots
Old May 22, 2014 | 12:40 PM
connoisseurr
I'm very eager to see the results.
Old May 22, 2014 | 02:06 PM
828's Avatar
828
Same here. $22 is worth not having to attach the resistor. Would be even better if they had same concept but for switchback
Old May 22, 2014 | 03:30 PM
socialconflicts
i will wait for someone else to verify this. when are you expecting the turn signal bulbs to come in?
Old May 22, 2014 | 03:33 PM
connoisseurr
Just took a gander - looks like they only offer solid color LED bulbs for the front turn signals and not switchbacks.
Old May 22, 2014 | 03:57 PM
828's Avatar
828
Looks like they do exist
No Resistor Required Error Free 1156 LED Turn Signal Light Bulbs
Old May 22, 2014 | 04:59 PM
socialconflicts
those are discontinued.. : \
Old May 22, 2014 | 05:39 PM
connoisseurr
Originally Posted by 828
Not for the 7443 bulb type which is what the 2010+ requires
Old May 22, 2014 | 06:37 PM
socialconflicts
are these the ones you are saying?
Plug-N-Play Error Free 7440 LED Turn Signal Lights, No Hyper Flash
Old May 23, 2014 | 01:19 AM
ANMVQ's Avatar
ANMVQ
Ok so the turn signals DO not hyper blink and work perfectly and look GOOD
The reverse lights look just as good both are really bright vids tomorrow before I. Leave for work , BUT the front markers are a waste , the bulbs are to long they hit the inside of the housing and I can't lock them in so I'll be calling tomorrow to return those .
But like I said the turns do not hyper blink and look very good .
Great option for us .
