Are shattered fog light covered?
Old Feb 26, 2014 | 07:10 AM
Snaoum's Avatar
Snaoum
Are fog light housings that get shattered from a rock usually covered by warranty? Got a 2011 G37 with 27k on it and I am curious if warranty covers suck items.
Old Feb 26, 2014 | 07:39 AM
Modme's Avatar
Modme
No, just like how warrant does not cover accidents.
Old Feb 26, 2014 | 07:42 AM
Snaoum's Avatar
Snaoum
Ok thanks for the reply, was just curious.
Old Feb 26, 2014 | 07:44 AM
elrey85's Avatar
elrey85
I dont think that is covered by warranty but It might be more of an insurance claim if it is worth it. I hit a rubber cone when Sandy hit and cracked my passenger foglight. I Bought one from here Infiniti G37 Fog Lights at AM Autoparts and installed my self. Pretty straight forward install. Def cheaper than dealer.
Old Feb 26, 2014 | 12:30 PM
atlg37ss's Avatar
atlg37ss
Did you have to take off the bumper to do the install?
Old Feb 26, 2014 | 12:32 PM
Snaoum's Avatar
Snaoum
Seems it can be done without removal of the bumper. Removing the plastic cover under the car seems to be a good option.
Old Feb 26, 2014 | 01:31 PM
elrey85's Avatar
elrey85
No you dont have to take out the bumper. I had to remove the wheel tho cause it gets in the way. Then take out the Fender Liner so you can get access behind the bumper.
Old Feb 27, 2014 | 12:42 PM
atlg37ss's Avatar
atlg37ss
ordered a pair from AM Mortosports yesterday, gonna put them on this Sat, thanks guys!
Old Mar 11, 2014 | 02:28 PM
chopper's Avatar
chopper
"Easy" fog light replacement
Just for info. About two weeks ago, I took a rock in my passenger side fog light that shattered the front lens. Curiously, the bulb was untouched, but the lens was 80% gone by the time I got home. Anyway, I called the local dealer just to see what they would charge to replace the fog light assembly; quote was $340 installed. I thanked them politely for the info and then went to Amazon.com and ordered two fog lights from a company called AutoHalo. These are aftermarket replacement parts but had "NISSAN" stamped on the side for what that's worth. I got two complete fog light assemblies (including bulbs) for $103 shipped to the house and had the broken one replaced in less than an hour. It seemed to be an exact functional replacement except that the raised lettering on the front lens was different from the original on the other side. I could have done the whole job in less than an hour but I was puttering around behind the bumper for the first time. I did a search and found a link where someone claimed to be able to pull the fog light without going in from the wheel well, but I found that the washer fluid reservoir is directly behind the fog light on the passenger side and I could find no way to get around it to remove the 8mm bolt that holds the light in. So I pulled the wheel and the lower pan, and then loosened the fender liner enough to get to the back side of the light. The chrome trim ring around the light just pulls off, and then it's just 10mm bolts for the plastic pan, the little plastic push plugs for the fender liner, and an 8mm bolt holding the light in from the rear.
Anyway, if anyone is interested, here's the link:
Robot Check Robot Check
Amrit.bhathal
Car Care & Detailing
Dec 29, 2015 12:20 PM
tomro99
Nov 17, 2015 02:08 AM
tomro99
OldG37
Sep 6, 2015 10:38 PM
