H.I.D help
H.I.D help
Hey everybody I have a 2010 G37 sedan and I recently tried to change out my bottom fog light with a H I D kit but I plug everything up and they did not come on. So I tested them out on the battery to see if the h I D's worked and they come on so I was wondering what I need to do?
I had a similar issue.. Check to make sure this connector isn't the culprit as it was for me... If i didn't get the metal prongs to fit just right in the assembly then they wouldn't turn on for me...
H8/H11 Male Wire Connectors
EDIT: I have the Xetronic Elite Kit, and still ended up buying that connector from HIDConcept in lieu of the one that came with the kit... Hope that helps.
stevelam
Mar 12, 2011 01:05 PM
