Fog Light Bulbs DIY
Old Sep 20, 2013 | 09:39 AM
jmoney6's Avatar
jmoney6
Fog Light Bulbs DIY
Does anyone have a DIY on a good way to approach the fog light bulbs?
Old Sep 20, 2013 | 09:47 AM
rks's Avatar
rks
grease up your wrist and slide it behind the splash shield. the passenger side is a little tougher since you have to squeeze by the washer fluid reservoir. i think if you search there are detailed instructions on this site but it's a relatively easy job. look in your owners manual or the excellent FSM sticked at the top of the G37 Sedan forum.
edit: this is for the fogs in the bumper not those integrated into the main housing (there are a few DIY stickies for that as well).
Old Sep 20, 2013 | 10:06 AM
Use a pen-light to get oriented. Turn the bulb housing and pull it out of the fog assembly, rather than trying to disconnect the wire harness while still seated.
You will get scratched up. Helps to have thin little girly arms.
Old Sep 21, 2013 | 03:02 PM
onelovechicago's Avatar
onelovechicago
go through wheel well, very easy and you're able to actually see the fog housing
Old Sep 21, 2013 | 04:00 PM
inspector94's Avatar
inspector94
I just took the wheel off and it was a piece of cake then to try and work with the little gap you get .
tomro99
Nov 17, 2015 02:08 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
dlc1988
Sep 2, 2015 09:40 AM
