Fog Light H1 LED Replacement
Old Aug 27, 2013 | 12:49 AM
G3710's Avatar
G3710
Lightbulb Fog Light H1 LED Replacement
Considering replacing my fog light bulbs with these H1 LED bulbs. I am doing this for cosmetics, anything I should be aware of?
Also how can one drive with only fog lights on during the day all other front lights off?
Ty!
-G3710
http://store.ijdmtoy.com/12-SMD-LED-..._h1_sku_4g.htm
Link to G37 bulbs:
https://www.myg37.com/forums/attachm...bulb_specs.jpg
Old Aug 29, 2013 | 03:22 AM
glennp_2012's Avatar
glennp_2012
Yes the right side is a bit more challenging to replace. You will need a close wrench ratchet size 8. Undo this one nut at the back to make the access easier otherwise it will be a biotch to install the replacement bulb. If I remember correctly the last time I did this on my Acura I tapped into the the turn signal to get constant power. This will make your fog independent and you can turn it on and off at will. You can search youtube that's where I saw the DIY on it. Some pics of my HID fog and LED interior lights after install.
Ty!
-G3710
H1 LED Bulbs Infiniti G37 Fog Lights Honda S2000 DRL Daytime Lights
Link to G37 bulbs:
Attached Thumbnails Fog Light H1 LED Replacement-2012-08-22-19.29.17.jpg   Fog Light H1 LED Replacement-2012-08-22-19.29.04-1.jpg   Fog Light H1 LED Replacement-2012-08-22-19.47.31-1.jpg   Fog Light H1 LED Replacement-2012-08-22-19.48.16.jpg
Old Aug 29, 2013 | 07:07 PM
G3710's Avatar
G3710
Do you have any pictures from a distance? What bulbs did you go with?
Old Aug 30, 2013 | 03:02 AM
glennp_2012
No I don't have a shot from a distance and the bulbs I got from Diode Dynamics fast easy install comes with all the instructions.
vamarris
Dec 9, 2018 11:10 AM
timc00k
Feb 15, 2017 09:15 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
