Dash Cluster Light Flickering
Old Aug 22, 2013 | 04:58 PM
Dk43086's Avatar
Dk43086
I just purchased my 2008 g35x less then a month ago and my tachometer light is flickering and the needle gets stuck around 3k rpm on the freeway. It gets un-stuck once I get off the freeway but it has been around 95 degrees so I'm ASSUMING that is the problem. I've searched to figure this problem out but seems like its just the led going out. Then I saw that some have had battery issues as well but I'm guessing this is not a symptom to that because other accessories work fine in the car and starts just fine. Therefore I've decided to replace the whole dash cluster but I'm not sure which cluster will be compatible bc I have a g35x, will a g37 non awd work? Will the newer updated cluster work? Thanks in advance
604gz
Sep 22, 2015 08:42 AM
pcwd
Sep 15, 2015 10:06 PM
CasperG37
Sep 14, 2015 07:46 PM
B Feelgood
Sep 13, 2015 05:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
