Help 35w to 55w is a big no-no, right?
I'm wanting to change my front fog lights (13 coupe) to a yellow PIAA or soemthing similar. All I see in H11 is a 55wx2=110w!!! type advertising.
The H11 that are in the car are 35w, so I'm pretty much guaranteed to have a distortion/meltdown issue aren't I?
We don't carry 55 watt kits because of how much hotter they run.
Your chances of melting your housing and damaging expensive factory components goes up exponentially when using 55 watt over 35 watt.
Admittedly, the 55 watt kits do have more output, but it's not worth the risk IMO
Nick C.
Nick C.
I'm pretty sure they are talking about the 35w HID kit recommended over the 55w hid kit. The manual is correct stating that the OEM fog light is a h11 55w bulb. 35w hid kit vs 55w halogen is not the same as what you're thinking (35w halogen vs 55w halogen).
Oh ok, I didn't realize they were referring to HIDs. It sounded to me like the OP said the car came with H11 35W from the factory. My mistake. Alrighty, so I'll be ok with aftermarket 55W halogens, thanks.
Do you mean you recommend using 35w HID vs staying with 55w halogen, or are you saying to use a 35w halogen? I just want to make sure I understand this clearly because I read elsewhere that the wattage between the bulb and ballast should match. Thanks.
You can mix and match HID bulbs with different ballasts, but the 55w ballasts decrease the lifespan of the bulbs quite a bit IMO
Nick C.
