What size/diameter LED Halo ring for the OEM Shroud?
Does anyone happen to know what size/diameter the oem shroud is for a 12/13 sedan (xS if that matters).
I am going to purchase a set of halo LEDs however I have the option of buying:
60mm, 70mm, 80mm, 90mm, 100mm, 120mm and 140mm
which size do I need in order for it to fit directly onto the shroud, similar to the following:
I know coupes and sedans are different, so please share both if available.
thanks!
thanks!
I have the STi-R lenses to replace the stock lenses, they're 3" OD, the coupes are 2.5" OD, so I assume a 3" ID halo should fit.
http://www.theretrofitsource.com/index.php?cPath=29
Clear Lenses from The Retrofit Source Inc
I was trying to find an answer as well. The OEM projector can take either a 90mm or 100mm halo. This is coming from LightWerkz and several other guys who do headlights on the G. The turn signal also takes a 90mm halo. Morimoto XSB and Diode Dynamics HD are the best LED Halos on the market for the G.
redlinernyc
Feb 29, 2016 11:06 PM
