Custom LED DRL's
Old Dec 19, 2012 | 01:37 AM
  #31
xxg00w0's Avatar
xxg00w0
Originally Posted by NeuroG37spine
Heres a few more pictures of the Aero pieces throughout the stages of paint and placing the wire backing.
which type of LED strip did you used?
FIRST 2 Xenon White 48 LED Flexible Side Glow Strip Daytime Running Driving Fog Light | eBay
SECOND New 5M Waterproof 5050 300 LED SMD White Flexible LED Lamp Light Strip Car Auto | eBay
Old Dec 19, 2012 | 01:39 AM
  #32
SgtGoldy's Avatar
SgtGoldy
I think I would individually wire up each led to make them less in number. But either way awesome DIY
Old Dec 19, 2012 | 11:07 AM
  #33
NeuroG37spine's Avatar
NeuroG37spine
WFLB-xx series Waterproof LED Flexible Light Bar | Side Emitting | Flexible LED Light Strips | LED Light Strips & Bars | Super Bright LEDs
I believe this is the strand i used. I definitely with Superbrightleds.com because of their quality reputation. Secondly i went with this strip because of how they wired in a series configuration. Every 3rd light can be cut. I actually cut 6 lights off of each side to fit the length i was going after.
I wired them together, but grounded each side separately. I also added a switch just in case i ever wanted to turn them off.
Found a pretty sweet touch sensor switch that is completely flat so blend in under the dash entirely flush. I put the switch in one of the empty slots to the left under the steering wheel. I'll take pictures of this as well.
I wired all the light wiring near the cabin filter (took out the glove box to get to this) and then behind the stereo to the switch. There is probably a better way but trying to go through the wiring grommet seemed to be a hassle so I went this route instead.
Old Dec 19, 2012 | 01:21 PM
  #34
Shift's Avatar
Shift
This picture is great and it reminds me of these which i would love to see installed on a G37
Old Dec 19, 2012 | 01:44 PM
  #35
NeuroG37spine
^^^^ That doesnt look too terribly difficult. I haven't done my headlights yet, but i wanted to do something unique to those as well. I will keep you guys posted on what i come up with.
Old Dec 20, 2012 | 12:24 PM
  #36
Shift's Avatar
Shift
If you go with LED strips on that video then you'll be the first on this site to do that mod since no one has tried it yet. It really is unique hopefully you choose this mod! Let me know what you decide!
Old Dec 26, 2012 | 12:58 PM
  #37
NeuroG37spine
Here are a few pics of the switch I used. Its completely flush with the lower console and is a touch sensor. When on it has a blue light showing and when off it has a red light showing. I have never actually turned them off while driving, but i thought i might install it just in case. Plus i have a few empty slots anyway, so why not.
Attached Thumbnails Custom LED DRL's-20121221_172147.jpg   Custom LED DRL's-20121221_172205.jpg
Old Dec 26, 2012 | 01:10 PM
  #38
Shift's Avatar
Shift
That looks great! Where did you get the switch and was it hard to install? Im surprised more people dont add a custom switch to their DRL's
Old Dec 26, 2012 | 02:02 PM
  #39
NeuroG37spine
surprisingly I got the switch at autozone. And it was somewhat just because it didnt come with any instructions on what the 3 prongs on the bottom of the switch actually did. So i had to kind of figure that out on my own.
Old Dec 26, 2012 | 02:07 PM
  #40
wblhockey14's Avatar
wblhockey14
looks good sir
Old Dec 26, 2012 | 04:23 PM
  #41
Awooo21's Avatar
Awooo21
What brand led lights did you use?
Old Dec 27, 2012 | 12:30 AM
  #42
xxg00w0's Avatar
xxg00w0
how did you wire the switch to the lights?
Old Dec 27, 2012 | 01:59 AM
  #43
ko3r's Avatar
ko3r
looks too gooood.
Old Dec 27, 2012 | 08:26 PM
  #44
NeuroG37spine
If you look through the entire post you will find the website link that I posted.
Thanks guys glad you like it!
Old Dec 27, 2012 | 08:30 PM
  #45
NeuroG37spine
on the back of the switch, there are 3 prongs. ground, accessory, power. I ground the switch to a bolt near the stereo. the accessory prong goes to the lights and the power prong i hooked up to a power wire near the stereo as well.
