DRL issue at night
DRL issue at night
Hey guys!
I just purchased a 2008 G37 coupe S and I've noticed that when my HID are on , I get only one DRL on (passenger side)
. But when I turn off the HID's I have both DRL working.
Hope you guys can help !
Thanks
. But when I turn off the HID's I have both DRL working.Hope you guys can help !
Thanks
I am pretty sure with HIDs ON (low beams) the DRL should turn OFF on both sides. Are you sure it is not the Fog lights. Drivers side burnt out? I believe fogs only work with the low beams ON. Check if your fogs are ON. If so turn them OFF and ON to see.
Ok I double checked everything and realized that the fog light (h1) are working properly , same for DRL . Now when the low beam HID are on and fog lights off, theres a small bulb not lighthing on under the DRL (h1) . I searched the owners manual and found out it's the clearance bulb thats out ( same size as licence plate bulb ). Size seems to be 194. I will check tomorrow where to get it. Whats stressing me is that I have to pass inspection friday morning :s
pcwd
Sep 15, 2015 10:06 PM
