OEM Daytime LED Copy
Old Aug 30, 2013 | 10:27 PM
  #121
gee wiz's Avatar
gee wiz
Originally Posted by qpham45
Those are ebay LED lights. I had bought a pair for like $3 too fool around with it a long while back. When I spliced open the wires I noticed that the gauge wire was really really small and to top it off they used toilet paper as an insulator of some sort! Thats a huge fire hazard! You're best bet is to make those LED lights yourself. Let me know if you need help.
Here is what my LED bulbs look like. Those large resistors are a must have for the power output.
https://www.myg37.com/forums/g37-sed...-drl-fogs.html
Thanks for the reply and info! Since the LEDs are already installed, do you have any recommendation on making this setup work, or will I need to scrap it out and install all new parts? The LEDs have not created any problems, the relay just gives out prematurely. Guess I should have popped for OEM in the first place.
Old Aug 31, 2013 | 07:15 AM
  #122
KEG97's Avatar
KEG97
I originally purchased an ebay setup, installed it, wasn't happy, and got the Phillips DRL set. MUCH happier. I suggest you go that route.
Old Sep 2, 2013 | 11:43 PM
  #123
gee wiz's Avatar
gee wiz
Originally Posted by weird60625
i have the same set up since i bought it from OP, it works fine at few first month then about 5 mons the LEDs are not off when the car is off . LEDs stay on even i turn of the car ignition .
Interesting...the LEDs decided to start working again on their own two days ago. Then today I parked the car and noticed they stayed on, would not shut off. Definitely an issue with the cheap modules/relays. If I could only find a quality module I might be set. An exhaustive search found nothing but the cheapo's. Frustrating...
Old Sep 3, 2013 | 06:38 PM
  #124
vaio23's Avatar
vaio23
Maybe you just got a bad harness, mine have been working perfectly the whole time?
Old Sep 3, 2013 | 07:57 PM
  #125
stockae92's Avatar
stockae92
Which Philips DRL you got? would it auto dim when the low beam is on?
Old Sep 3, 2013 | 10:17 PM
  #126
KEG97's Avatar
KEG97
$75 dollar kit on Amazon. I set it up so mine are on all the time....ala true DRLs.
Old Sep 3, 2013 | 11:36 PM
  #127
gee wiz's Avatar
gee wiz
What would be bad about the harness? On the first failure I tested the lead wires to the module and had proper voltage right up to it, but no power out. Replaced the module and all worked fine for a while. The fuse has never blown and all LEDs have lit fine when the system works, so I don't suspect a short in the harness or connections. In fact, I originally had issues with the connections, so I wire-nutted them all and sealed them with liquid tape.
When they wouldn't shut off yesterday, I removed the fuse and heard a click in the module. When I reinserted the fuse this morning, nothing, no LEDs again. Wish I could buy the Philips module only, but looks like I'll have to purchase the whole kit. I don't particularly like the Philips LEDs. I want to keep the OEM look with the OEM style LED housings, especially since I have the holes drilled in the grilling for them.
Old Sep 4, 2013 | 09:40 PM
  #128
KEG97's Avatar
KEG97
http://i43.photobucket.com/albums/e3...97/photo70.jpg
Old Sep 7, 2013 | 09:32 PM
  #129
Bladerunr's Avatar
Bladerunr
Can you describe the installation? How are they mounted? What color light do they put out? Can you take another picture of the mounting up close? thx
Old Sep 9, 2013 | 01:08 PM
  #130
stockae92's Avatar
stockae92
Thanks, I would probably go for that. Sounds like the installation is simple enough.
Did you have to take the bumper off for installation?
Old Sep 9, 2013 | 02:28 PM
  #131
KEG97's Avatar
KEG97
I'll get pics on Weds but my car is actually in the shop right now for some minor body work. A lady backed into the side of my rear bumper.
No need to take off the bumper. My guy had it on a lift and peeled back the plastic cladding on the underside of the car to install the lights. Then he worked the wires to the battery terminal. Clean install and it took him less than 90 mins for both lights.
Old Jan 7, 2014 | 12:02 PM
  #132
sesegal99's Avatar
sesegal99
Keg97 Please provide link to the kit you got on amazon....did you need to install any resistors or anything??
Old Jan 7, 2014 | 02:14 PM
  #133
KEG97's Avatar
KEG97
Amazon.com: Philips 12820WLEDX1 DayLight 4 High Powered Luxeon LED Daytime Running Light: Automotive Amazon.com: Philips 12820WLEDX1 DayLight 4 High Powered Luxeon LED Daytime Running Light: Automotive
No need for anything else. Don't hook up the one wire to the light if you want a true DRL experience. My lights are on anytime the car is on and they turn off immediately when the car is shut down.
Old Jan 7, 2014 | 04:17 PM
  #134
stockae92's Avatar
stockae92
The 8-LED version is getting much cheaper now, and the 8-LED version will auto dim when your headlight is on. (when you wired the control unit properly)
Philips 12824WLEDX1 DayLight 8 High Powered Luxeon LED Daytime Running Light : Amazon.com : Automotive Philips 12824WLEDX1 DayLight 8 High Powered Luxeon LED Daytime Running Light : Amazon.com : Automotive
I have this 8-LED version on my other car. On full power at night, its really too bright for on-coming traffic and would produce a lot of glare. I ended up wiring the control unit properly so that it will auto dim when the parking light is on. So that I am not blinding everybody else on the road.
Old Jan 7, 2014 | 10:00 PM
  #135
Darth Kinetic's Avatar
Darth Kinetic
DIY with pics plz
