DIY fixing bubble in seat, and pealing dash
My G37s has two of the common cosmetic issues I have seen on this site. The bubble in the leather seat where your wallet would set, and the corners lifting/ peeling on the edge of the gauge cluster.
I am thinking I can use a syringe and inject a small amount of apolstery glue into the seat bubble, then press it flat end even. Seems like the cause of this bubble is that the leather delaminates from the foam underneath. Using a syringe to inject some 3M apholstery adhesive under the bubble should help bind them back together and provide a flexible joint. Let my know if my idea is flawed or just plain stupid. Car is 2008 so out of warranty.
Next up is the peeling of the gauge cluster corners. It is very mild in my case, but couldn't I just use epoxy or super glue and using a syringe squirt a small amount of super glue gel back into the crevice then apply pressure until it cures. Again, feel free to let me know if the idea is good or sucks.
Thanks,
Randy
Thanks,
Randy
The leather seat sounds like a good idea. But to be honest I don't know much about stuff like that so I'm not sure. Good luck though! I wish more of the experienced people on here had some input...
I would say the gauge cluster idea is a good one.
As far as the seat bubble, hopefully the leather didn't stretch. I would imagine if it did, you'd see wrinkles after you got it glued down. And if you're gonna use a needle to "inject that glue...poking holes in the leather seems like it would be a bad thing.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
seat bubble
I work for a seating company and do upholstery work on the side. The bubble is more than likely do to the leather stretching. Unless they do things different from what I have seen, the leather is not attached to the foam. There normally is a layer of foam sewn to the leather at the seam lines only. I will know in a week or so if that is the case as I have purchased a sport seat to tear apart. The process that you mentioned about gluing may cause more problems.
seat bubble
Remove your wallet? Well I don't have a "fat" wallet. Even without a wallet I still get the bubble. I have noticed that after shifting into 6th and I put my foot on the foot rest that my left leg rests more on the seat while my right leg is elevated which causes a greater pressure in a localized area on the seat. With the seats made the way they are something has to give and it is the leather (stretching).
I have a small bubble on the left and a larger bubble on the right. I have also notice that the bubbles reduce over time when the car sits. As the leather dries it shrinks.
I haven't had a chance to take the seat that I bought apart to check the construction. but will in the near future. I will report on my findings when I can.
photocat
09-14-2015 02:32 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
