How to remove Bluebat headlights vinyl DIY?
Old Jan 25, 2012 | 05:17 PM
Jayson's Avatar
Jayson
I searched a while but it all came up for install them not remove them, is there anyway or step to remove them well? really don't want anything ruin my headlights, and wat to do after remove them can make the headlights looks better cleaner
Old Jan 25, 2012 | 05:32 PM
Rad_Slinger's Avatar
Rad_Slinger
i would imagine a hair dryer and goo gone would work ok. then you could just buff with a headlight restoration goop.
but why would you install it then remove it? curious because i'm contemplating doing my rear lights in bluebat stuff.
Old Jan 25, 2012 | 07:37 PM
BluestickG's Avatar
BluestickG
i actually just removed mine. looked good but i painted the housings instead. looks cleaner. I used a heat gun and it pealed right off. Then i used some headlight lens cleaner.
Old Jan 26, 2012 | 01:09 AM
Jayson's Avatar
Jayson
Where did you do your painted housing? man I don't have a heat gun hair dryer works too?
Old Jan 27, 2012 | 01:49 PM
seymore4's Avatar
seymore4
A hair dryer will work fine, even better IMO because it doesn't get as hot as a heat gun and less chance of burning stuff. Just heat it up a little and starting at the edges peal it off, use the goo gone to get the gunk off after.
Raleclair
Oct 8, 2015 02:06 PM
mahadeod
Oct 6, 2015 01:02 PM
takeapieandrun
18
Sep 27, 2015 12:36 AM
philttz
Sep 21, 2015 11:12 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
