Headlight tint removal and painted housings project
Old Dec 19, 2011 | 04:59 PM
1NEETO's Avatar
1NEETO
Ok I took the whole weekend to do this. Removing that tint was a complete pain in the *** and took the most time. If it wasn't for that tint, I would have done the whole thing in a few hours.
Ok here's the pics:
This is how it looked like.
I did not notice how much light output was affected until about two weeks ago when I drove a 2011 sedan loaner. That's when I realized I have to fix it.
Removing tint with laquer thinner. This section took about half an hour and lots of elbow grease.
What's for dinner? Roasted headlight.
Tint removed and sanded.
Housings painted. Headlight bezel is flat black and housings I painted them with rust oleum black night metallic paint.
Finished work.
Paint used:
The headlights still need some more restoring work. I used 1000, and 2000 grit sand paper and wet sanded it. I'm gonna try 600 and 800 and the use the 1000 and 2000.
And of course after all this work, some ******* breaks my driver side mirror. Haters.
Old Dec 19, 2011 | 05:17 PM
Weiboy718's Avatar
Weiboy718
You're gonna need a rotary buffer to get those 1200-1000 grit off the lens.
Old Dec 19, 2011 | 05:21 PM
1NEETO's Avatar
1NEETO
I used the mother's earth headlight restoration kit which included a buffing attachment for a drill. Maybe I need to keep buffing the hell out of it.
Old Dec 19, 2011 | 08:46 PM
Unique Bliss's Avatar
Unique Bliss
Any condensation or fogging issues with the lights after putting them back together?
What did you use to seal you lights backup?
Thanks.
Old Dec 19, 2011 | 09:18 PM
1NEETO's Avatar
1NEETO
No condensation issues so far. I used permatex black RTV. I used a whole tube for both headlights but quite frankly you should use about two thirds of a tube per headlight. But So far no condensation.
Oh yeah don't forget the super glue! I broke a few tabs on my headlight assy trying to open it up!
Old Dec 19, 2011 | 09:20 PM
Weiboy718's Avatar
Weiboy718
trust me! that buffing wheel will not remove 1200-1000 grit sandpaper! you will need a rotary buffer with a very aggressive buffing pad!
Old Dec 19, 2011 | 09:28 PM
1NEETO's Avatar
1NEETO
I might just get them professionally restored. I don't have a rotary buffer and I'm not going to buy one. No big deal really, the headlights are so much brighter already!
Old Dec 19, 2011 | 10:29 PM
08_g37s's Avatar
08_g37s
how hard is this process? i wanna do it i am just a little nervous of baking my headlight...and opening it without damaging it
Old Dec 20, 2011 | 12:40 AM
tbone12's Avatar
tbone12
great job, looks much better!
Old Dec 20, 2011 | 01:59 AM
1NEETO's Avatar
1NEETO
Baking the headlight is nothing. 200 degrees is not that hot at all. Things get much hotter inside the engine bay that's for sure. the critical part is to open up the lens fast enough before the sealant cools down. I had to bake them twice because I wasn't fast enough.
As for difficulty, well of you're not mechanically inclined I think you should not attemp it. Removing the bumper alone can be a daunting task for those who are not comfortable with tools. taking the headlight apart is the easy part. Getting the headlights out and installing them is what can be daunting. oh yeah don't forget the super glue because you might break a few things!
Thanks! I think so too and boy are those headlights bright!
Old Dec 20, 2011 | 02:53 AM
08_g37s's Avatar
08_g37s
i installed the stillen gen 3's myself so taking the bumper off isnt an issue ... i might do it when its nice out (spring) unless i get a nice weekend day
Old Dec 20, 2011 | 03:01 AM
1NEETO's Avatar
1NEETO
If you have removed the bumper in the past then this is nothing. Once you remove the bumper, there's only 4 bolts that hold the headlight.
jfisher
Apr 25, 2017 01:22 PM
cconklin2
Jan 9, 2016 07:21 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
tomro99
Nov 17, 2015 02:08 AM
uzbekuz
Sep 8, 2015 11:45 AM
