Passanger aibag off light is ON and buckle up light is on,even nothing on seat.
Old May 5, 2011 | 01:39 AM
sobi6111's Avatar
sobi6111
Exclamation Passanger aibag off light is ON and buckle up light is on,even nothing on seat.
On my 2010 FX35. After I start car passanger aibag off light is ON and buckle up light is on,even nothing on seat and it stays this way .
Any ideas? if I put my friend on a seat and he buckles up it will go off after 1-2 minutes,as soon as he leaves the seat buckle up sign and airbag off lights goes on as well
Anyone had same thing?
Old May 5, 2011 | 02:26 AM
devil2k's Avatar
devil2k
mine did that on cold days like -4 degree. dealer couldn't do anything about it.
Old May 5, 2011 | 02:55 AM
sobi6111's Avatar
sobi6111
Buckle up light was on as well even none was in passenger seat?
Old May 5, 2011 | 10:06 AM
devil2k's Avatar
devil2k
Yep. They told me that once the car warms up it'll be fine but sometimes they stay on even after I've driven around for 15 mins.
Old May 5, 2011 | 11:28 AM
bitNine's Avatar
bitNine
There are weight sensors in the seat. Dealer may need to adjust them. This was a common problem in my old car.
Old May 5, 2011 | 11:32 PM
eksigned's Avatar
eksigned
Your old car being...? Another G?
eksigned's Avatar
eksigned
Maybe pull the negative terminal? You'll lose all your information though, including oil change interval, etc.. Not sure if resetting the ECU will help? There's a DIY in the DIY section.
Old May 6, 2011 | 01:34 AM
sobi6111's Avatar
sobi6111
Car is 2010 FX35. Pretty much same as G37 :-) the interior wise. I did try to reset ECu and etc. Same thing. Annoys me.
Any more ideas? Is it time for a dealer visit :-( ?
Old May 6, 2011 | 04:22 AM
devil2k's Avatar
devil2k
I was told that "these high end cars have lots of electronics that weren't built for the Canadian winter" and the problem was never addressed. I wonder if one could sue Infiniti if airbag(s) fail to deploy in a collision.
Old May 6, 2011 | 10:20 AM
apexi957's Avatar
apexi957
I had the same issue a long time ago, when I initially did the nav bypass. I didn't do it properly so the passenger airbag light off would always be on.
Infiniti did tell me that if there was a crash the airbags would not deploy.
Old May 6, 2011 | 11:55 AM
devil2k's Avatar
devil2k
Mine is totally stock.
Oh lovely, I can't believe they actually have ***** to tell people that when they spend 40~50k on a car.
Old May 6, 2011 | 02:34 PM
KLB's Avatar
KLB
He messed with the wiring of the car. What would you expect them to tell him?
Old May 6, 2011 | 02:58 PM
devil2k's Avatar
devil2k
Actually they told me the same, and mine is 100% stock.
Old May 7, 2011 | 02:29 AM
apexi957's Avatar
apexi957
I fixed the wiring now, so the car is AY OKAY lol. Airbag light works properly now.
Old May 7, 2011 | 06:59 AM
sobi6111's Avatar
sobi6111
They found out you did NAV mod? Did they void your warranty? Or they told you just connect everything back together and it will fix airbag light?
How did you fix it?
