Seat heater switches from 2009 G37 coupe
Old Feb 23, 2011 | 10:20 PM
dmcconnell68's Avatar
dmcconnell68
I give up on searching this forum, so I'll just ask...
Does anyone know if the **** style seat heater switches and trim piece from a 2009 G37s coupe will fit a 2008? I hate those cheap Radio Shack rocker switches on the 2008.
Thanks,
David
Old Feb 23, 2011 | 10:24 PM
SRG's Avatar
SRG
I actually prefer the rocker switches..... IMO.....but I'm pretty sure you cant swap them..
Old Feb 23, 2011 | 10:33 PM
shumby's Avatar
shumby
will not swap. cuz if they could i would send you mine from my 09 and i would gladly take the 08's . man I miss my 08
Old Feb 23, 2011 | 10:44 PM
breftayka's Avatar
breftayka
The factory switch is just a three way toggle switch right? If you just taped off the low heat power wire, couldn't you just introduce a dial type/resistor switch? I could see why the 08 wouldn't fit the 09 as you may have to wire in the low heat? How many pins on the back of the 09 switch?
dmcconnell68
I'm curious, what do you miss about the 08, other than the switches, that the 09 doesn't have?
Old Feb 23, 2011 | 11:08 PM
MoonliteMadness's Avatar
MoonliteMadness
I don't think you can swap them since the ****-style found on the 2009's allows you to select 6 temperature settings. IMO this is way better than a rocker switch with just high and low settings.
Old Feb 23, 2011 | 11:11 PM
breftayka's Avatar
breftayka
That's why I asked how many pins are on the back of the **** switch. Could it just be like a resistor similar to the dash lights switch?
Old Feb 24, 2011 | 01:51 AM
tbone12's Avatar
tbone12
ehh, seems like swapping would be to much trouble for something that I hardly notice, but thats just me. However, I don't like how the 08's have that dummy switch in between the seat heating switches if you don't have the intelligent cruse control option
Old Feb 24, 2011 | 03:29 AM
dmcconnell68
I do have the ICC option, but I still have that blank button between the seat heater switches.
Old Feb 24, 2011 | 09:18 AM
JohnEnglish's Avatar
JohnEnglish
They used the same centre console as the sedan. In the sedan that's where the "Snow Mode" button goes if you get the AWD option.
Old Feb 24, 2011 | 09:29 AM
breftayka's Avatar
breftayka
You're right. Especially when using the heated seats down here happens about 5 times through the year. It just looks so much cleaner to me. I think the switch in between is for the convertibles to control the roof... I hate it too.
^^^ You're right this looks more like the button.
Old Feb 24, 2011 | 10:55 AM
Razorshock's Avatar
Razorshock
In my X Coupe the snow mode switch resides in that 'blank' that you're referring to.
I too prefer the dials, sometimes low can be not quite hot enough and high is can get too hot for me.
Old Feb 24, 2011 | 04:09 PM
tbone12's Avatar
tbone12
Oh ok, i gotcha, i just figured it was for ICC, but anyway I can see how several different settings could be nice.
Old Feb 24, 2011 | 04:12 PM
tbone12's Avatar
tbone12
haha yea I know, I hardly ever use my seat heaters. But I think it could be kinda cool to retrofit that dummy switch with a real switch for something, idk what though.
Old Feb 24, 2011 | 06:55 PM
JohnEnglish
ICC controls are on the right side of the steering wheel.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
Dsskyline
ECU Tuning / Dyno Data
91
Oct 9, 2016 01:24 PM
joeposter
Sep 8, 2015 04:36 PM
bikerjosh
Aug 19, 2015 11:26 PM
sedrick23
Aug 15, 2015 05:41 AM
