De-badging Questions
Old Jan 31, 2011 | 11:53 PM
Stevielu's Avatar
Stevielu
Hey forum! Thinking about debadging the "INFINITI" off of the trunk. Saw the DIY and it seemed pretty easy. The DIY said to use a adhesive solvent, but didnt specify which one/brand/etc. So my question to the people who have debadged something on their car, what solvent did you use? Where can i get it? Price?
And one more noob question lol. The DIY said that if there is a shadow from the badge left, you should wax it. What does he mean?
Thanks for the help!
Old Feb 1, 2011 | 12:00 AM
Steveo47's Avatar
Steveo47
automotive goo gone, less tan ten bucks from any auto store! you need to polish out the ghost of the emblem, i have a ****ting simonz polisher i used, but you could remove it by hand
Old Feb 1, 2011 | 12:13 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Goo gone, any kind of bug/tar remover, etc. I used Cheimcal Guys Bug and Tar Remover personally
The "ghosting" is just like a shadow that is left when you take the emblems off. I debadged mine after over a year and there was no ghosting whatsoever
Old Feb 1, 2011 | 02:38 AM
jamesshifflett's Avatar
jamesshifflett
The shadowing is only typically there on "older" cars b/c the paint gets lighter from the sun and the paint area under the emblem has been protected and is thus slightly darker. I just did my 2011 G and no issues...but did my 2005 maxima and had some light shadows.
Old Feb 1, 2011 | 02:47 AM
Doggy's Avatar
Doggy
debadging is the easiest **** ever!! I do it a lot for customers, everything comes of by hand, but if needed dental floss works best, then peel of the sticky with your fingers and use goo gone and bam! and if needed use a wax like turtle wax or whatever and polish it up. theres your 2 sentence diy!
Old Feb 1, 2011 | 08:35 AM
4drScreamer's Avatar
4drScreamer
Doggy, is there no damage to the paint finish with any of these solvents? Obviously the wax helps to refinish, but is the clear coat under the emblems capable of holding up to the solvents? I wouldn't want to to buff it with a light cutting compound then build back up the wax finish if the paint or clear coat is already compromised.
Old Feb 1, 2011 | 09:08 AM
1cleanG's Avatar
1cleanG
NextLevel Performance
yep, w/ these guys. Did it on both my 35 and 37. MAKE SURE to heat it up. They will come off like butta!
1. Soak it up good in goo gone.
2. take a blow drier or heat gun and heat it up
3. take a towel/fish line and just go right under the letters. They'll come RIGHT off! Then soak the towel in goo gone and the adhesive will come right off w/ heat as well.
tadah! one clean asssssssss!~!!
Old Feb 1, 2011 | 10:21 AM
Bo2point0's Avatar
Bo2point0
Question: What about the Mt. Fugi on the trunk?
Does this badge pin in the trunk lid?
If I remove this will there be 2 holes in the trunk?
Not to be a thread stealer, but I have been contemplating this for a while.
Old Feb 1, 2011 | 10:25 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
no, thats typical of Honda, but not the infiniti! You should be fine
Old Feb 1, 2011 | 11:27 AM
Stevielu's Avatar
Stevielu
Auto Goo Gone? Alright, sounds good thanks! But I have had my G since November 2007, do you think there will be a shadow after over 3 years?
Old Feb 1, 2011 | 12:25 PM
Fentress24's Avatar
Fentress24
I just used the Goo Gone as refered to by everyone else. I actually found it at the grocery store in the automotive section, try to soak the letters and adhesive pretty good. The blow dryer also makes this alot easier on the hands. I tried it without and the floss was cutting into my hands, but after heated up a little it came right off. Takes about 10-30 minutes and some elbow grease.
Old Feb 1, 2011 | 01:01 PM
hispeed-lowdrag
While this will work, it's far too much time and effort. Just spray some goo gone on there, take some floss/fishing line and string it between the car and the emblems. Done
Old Feb 1, 2011 | 01:05 PM
Djfarhan's Avatar
Djfarhan
happy debadging!
Old Feb 1, 2011 | 03:01 PM
Don Meshal's Avatar
Don Meshal
man i did mine and it was pretty easy ..
follow the steps that G37sam mentioned in his thread which i saw easier than any other
Old Feb 1, 2011 | 03:05 PM
SRG's Avatar
SRG
very easy process....if needed a nice buff =) Good luck! Post pics!
