Help Aftermarket HIDs not working?
Hey everyone, so i just recently installed the D2S Phillips 8000k bulbs on my g37 sedan. Whenever i drive, i always put my lighting on auto mode, so whenever its dark, it will automatically light up. Unforuantely, after i installed them, when the lights decide to light up, the xenons would flash once then go blank again. After i switch it into night mode and flip it back into auto mode, it will light up and stay on. I was wondering if anyone knows what the problem is? Will it be the connection problem? or will i need a new ballast? Thankss
i had same issue, but after i took out the LED clearance light and put back regular bulb it now working fine.
where did you buy your phillips 8000k? are you sure it's original Philips?
Phillips only makes 6000k as far as i understand
