issue with CF Hood
Old Jun 28, 2010 | 12:33 AM
Lee55's Avatar
Lee55
Unhappy issue with CF Hood
Does anybody have an issue with the SEiBON carbon fiber TS style hood regarding the water spray not fitting?
The vent that seems to be where I should install the water spray is smaller then the OEM hood .
Old Jun 28, 2010 | 12:54 AM
Weiboy718's Avatar
Weiboy718
i recently installed that for my friend and we had the same problem. there's no way you can get it in there unless you glue it with adhesives.
Old Jun 28, 2010 | 01:04 AM
ShyTown91's Avatar
ShyTown91
what did you guys do to solve this problem?
Old Jun 28, 2010 | 01:12 AM
Lee55's Avatar
Lee55
I was thinking of sanding it,but I'm afraid it might be loose .
Old Jun 28, 2010 | 02:38 PM
Lee55's Avatar
Lee55
anyone???
Old Jun 28, 2010 | 02:46 PM
STOOF's Avatar
STOOF
yeah theyre all like that. i just took a dremel and made it bigger, then used epoxy to glue the piece on.
Old Jun 28, 2010 | 04:51 PM
ucla bruin's Avatar
ucla bruin
Get some double sided 3M automotive tape. That's what I did and it held up fine.
__________________
Old Jun 28, 2010 | 06:03 PM
Weiboy718's Avatar
Weiboy718
That's the first thing I tried and it didn't hold. The one I did the holes were too big lol. So what we ended up doing was glue the whole thing on including the rubber molding.
Old Jun 28, 2010 | 06:42 PM
ucla bruin's Avatar
ucla bruin
Really? I just used the red 3M. You can get them from Home Depot for exterior/outdoor use, pretty heavy duty. I was able to pop it into a few holes, rest was held up by 3M. Dremel will always work too.
__________________
Old Jul 2, 2010 | 02:10 PM
wrathletik1's Avatar
wrathletik1
I had that problem too. I took it to a shop to get hood pins and while they did that, they made the holes bigger to fit the spray nozzles and the rest of the rubber part I used double sided tape, but it didn't hold up.
Eventually went back to stock because seibon sucks.
Bhodges7
G37 Convertible
Apr 5, 2016 02:17 PM
Striderx88
Oct 10, 2015 10:42 PM
acthesquid
Sep 18, 2015 06:31 PM
acthesquid
General Tech Questions
Sep 15, 2015 07:31 PM
