Review 6000K vs OEM HID with Pics
Old May 18, 2010 | 05:02 PM
Gee37S's Avatar
Gee37S
Alright thanks for the additional info!
Old May 18, 2010 | 05:31 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
if it is your first time changing the lights, I would take off the tires just so you can see where everything is. once you are comfortable with the feel of that area, you can either just turn the tires or go through the top.
but if you try going through the top w/o knowing where/how things are oriented be prepared to replace something b/c you'll probably break something
Old May 18, 2010 | 06:04 PM
Trincap's Avatar
Trincap
Nah I did all the lights through the wheel well except the fog light. The fog light is a reach through the wheel well and hard to see. Meanwhile, from the top? It's right there so it's a breeze. It's also so easy to go from the top. Three bolts, pull out, pull out the extender for the washer fluid and you have direct access.
Old May 18, 2010 | 07:11 PM
Gee37S's Avatar
Gee37S
I'll be doing the other bulbs through the top when I get them this week, I'll let you guys know which one I found to be easier. The D2S can easily be changed simply by turning the wheel, there was enough room to see how everything was put together back there, but once you reach in you can't see your hand at work. A rookie might have some trouble figuring it out without seeing what he's physically working on, but I've had quite some experience changing bulbs so I'm used to it.
Old May 19, 2010 | 01:12 PM
Gee37S's Avatar
Gee37S
Which bolts exactly? I tried looking around and I couldn't figure out what to unbolt to get to the parking light bulb. I think that I would have to remove the intake box but that seems like way more than 3 bolts.
Could you point it out on the pic?
Old May 19, 2010 | 01:24 PM
hispeed-lowdrag
yes, if you have the OEM intakes you will either need to take off the tires or take out the intakes (the intake would be MUCH easier)...with my Stillen Gen3 I can just reach in and get to it.
But with the OEM intakes it IS only 3 bolts/side
Old May 19, 2010 | 01:49 PM
Gee37S's Avatar
Gee37S
Really? I'll give it a shot when I get home.
Old May 19, 2010 | 02:04 PM
hispeed-lowdrag
with the passenger side lights, make sure you take out the washer fluid tube -- it gives you a lot more room to work
Old May 19, 2010 | 03:24 PM
Gee37S's Avatar
Gee37S
Sounds good, removed the driver side box it took like 2 mins, didn't have time to do the rest I'll finish it up when I get home tonight...
Old May 19, 2010 | 08:40 PM
Loi's Avatar
Loi
Looks good, I will be picking up some Philips Ultinon 6000K bulbs this weekend. It should be a breeze since I'll have the whole bumper off to install the Injen CAI. actually I'll have the wheels off too to install my KW's
Old May 19, 2010 | 11:44 PM
Gee37S's Avatar
Gee37S
Lights are done! Looks much better IMO. I rarely use the fogs, and when I do, I want max visibility so I will be keeping the OEM bulbs for those situations.
Thanks for the tips guys!
Old Jul 8, 2010 | 03:08 PM
g37xs_pilot's Avatar
g37xs_pilot
Looks good. Chrome blinkers were mentioned here several times, where did you guys pick those up? I have LED replacements enroute from V-LEDS for all interior, license, reverse and fogs, but haven't decided what to do with the blinkers yet...
Old Jul 8, 2010 | 03:25 PM
hispeed-lowdrag
search for HamstersG and look up his thread on it...he has the link to the "chrome dome" lights. I think it's autolumination.com but check his thread to be sure
Old Jul 8, 2010 | 03:38 PM
  #29
philter25's Avatar
philter25
^ Also, if you dont want to take off the tires, another option is to drop the front bumper quickly, and then just slide the headlights out further. I did that when taking out the sidemarker bulbs and it only took maybe 20 minutes from start to finish.
I think Igor posted a how-to on how to take the bumper off quickly which I used as a reference.
Old Jul 9, 2010 | 10:59 AM
  #30
g37xs_pilot
Yep, perfect, thanks, found his thread and ordered the full chrome amber bulbs. Also did my fogs last night and went thru the top to do it (with 6K VLEDS, they showed up yesterday afternoon.) Pulled the intake boxes, very easy, just enough room, will do my blinkers that way too.
