Washer fluid sprayer help
Old Sep 18, 2009 | 03:28 AM
jnguyen's Avatar
jnguyen
I don't know what happen to my washer fluid. It was working when I first bought the car. It would shoot 3 stream of water from each shooter on both side for a total of 6 streams. I then change to injen intake so I had to change the water reservoir. Everything was still working fine until I ran out of washer fluid. I refilled it with washer fluid and now it only shoots 1 stream of water on each shooter. I can't get it to shoot 3 no more no matter how full I fill it. I try check to see if I pinched the line or something. I took off my bumper and headlights and it still does the same thing
Old Sep 18, 2009 | 11:18 AM
jnguyen's Avatar
jnguyen
bumpin this up before I die when it snows
Old Sep 18, 2009 | 11:30 AM
Mid-Life Crisis's Avatar
Mid-Life Crisis
If you have to take off the bumper again, I was able to transfer the low-fluid sensor to the Injen red bottle. It works. Thinking to make a DIY.
Old Sep 18, 2009 | 11:32 AM
jnguyen's Avatar
jnguyen
Its not that I have low fluid. Its full but its not shooting correctly. Only 1 stream of water come out on both side
Old Sep 18, 2009 | 11:47 AM
GeeeeOhhhh's Avatar
GeeeeOhhhh
spray some kaboom! or clean the sprayers . it could have some crust on em.
Old Sep 18, 2009 | 11:48 AM
jnguyen's Avatar
jnguyen
Nah I try that. I use a toothbrush to try to clean them
Old Sep 18, 2009 | 11:49 AM
Use a very small pin to see if there is anything blocking the stream at the outlet of the jet. Ream it out and try again.
Old Sep 18, 2009 | 01:03 PM
KnoxvilleG37's Avatar
KnoxvilleG37
Damn, Betty beat me to it....yeah, use a pushpin in the holes of the sprayers that aren't working and ream out any crust. Should return to normal. Keep us posted.
Old Sep 18, 2009 | 02:53 PM
ucla bruin's Avatar
ucla bruin
Yes, what I was going to say too. The hole might be clogged. Happened to someone I know in So Cal.
__________________
Old Sep 18, 2009 | 04:27 PM
DrJones's Avatar
DrJones
J... when this happened to me I used a toothbrush to clean the spray nozzles.... turns out there was wax/residue plugging the outlets.... hope this helps..
Old Sep 18, 2009 | 04:31 PM
jnguyen's Avatar
jnguyen
Yeah i'm try what J and you suggest tonight. As soon I read your post I remember it happen not too long after I got my car detailed. I try a toothbrush already and got most the crust out but I never check to see if there was anything in the sprayer.
Old Sep 22, 2009 | 11:27 AM
UNV-IT46's Avatar
UNV-IT46
weird...... im having an issue with mine but not this. basically all my streams are shooting strong and straight. but they are not aimed right at all. all three of the drivers side streams shoot right up and over my roof. i tried adjusting the nozzles but nothing. i cant figure out what the hell is wrong
Old Sep 22, 2009 | 11:33 AM
ucla bruin's Avatar
ucla bruin
^Do you have a CF hood? Maybe it's not mounted straight anymore. I know one of my is not.
__________________
Old Sep 22, 2009 | 11:45 AM
wakeboardr116's Avatar
wakeboardr116
It might be me, but am I the only one who hates how the stream is on our cars? The problem is that it's an actual stream and not a mist. Infiniti seems to be the only cars like this. My moms mercedes and dads escalade are soooo much better. They both produce a fine mist that does a really good job of covering the entire windshield when you spray them.
Old Sep 22, 2009 | 12:21 PM
UNV-IT46's Avatar
UNV-IT46
nope all oem
