Help Vled bulbs dont fit?
Old Sep 18, 2009 | 11:37 AM
nogoodname's Avatar
nogoodname
Originally Posted by SOLISIMO
yeah I found the code earlier on but Ill be fine with the 4 led as long as its bright, I dont need a search light on my tag either
they are a bit brighter and it's a pure white colour.
I picked these to change the colour from yellowish to pure white without making them super bright, not interested for the popo's to see my plate from far... no offense
Old Sep 18, 2009 | 11:38 AM
SOLISIMO's Avatar
SOLISIMO
hahaha as long as the difference is nice, I dont care
Old Sep 18, 2009 | 11:40 AM
nogoodname's Avatar
nogoodname
so the ones i have on the original link wont fit anywhere else?
might fit in the dome and doors....
those have bigger enclosures
Old Sep 18, 2009 | 11:46 AM
SOLISIMO's Avatar
SOLISIMO
it wasnt the size that was the problem their was no way to connect the bulb
Old Sep 18, 2009 | 11:47 AM
jnguyen's Avatar
jnguyen
the bulbs you bought solis should be the same as a 194. Its a wedge
Old Sep 18, 2009 | 11:49 AM
SOLISIMO's Avatar
SOLISIMO
which ones the ones I said dont fit for the tag?
Old Sep 18, 2009 | 11:50 AM
lakers8's Avatar
lakers8
I bought those same ones for my reverse lights, only because you cant have them on for more than 15 minutes because they will burn out from the heat given off. So If i had put those in my plates or on the dome, which are used longer, then it would have been a waste of money. They work well though.
Old Sep 18, 2009 | 11:52 AM
SOLISIMO's Avatar
SOLISIMO
so the first bulbs I posted, will they fit in the reverse lights
Old Sep 18, 2009 | 11:53 AM
nogoodname's Avatar
nogoodname
that's impossible, i just looks and the dimensions and it's 9 mm wide... that's perfect and 2.5 mm thick.... perfect
go try it again, i posted pics about the licence plate light.... go look
NO, NOT for reverse light
Old Sep 18, 2009 | 11:55 AM
jnguyen's Avatar
jnguyen
the first link you post. They are a wedge and should fit in the same. Just look diff cause no enclosure
Old Sep 18, 2009 | 11:56 AM
SOLISIMO's Avatar
SOLISIMO
when I disconected the old bulb it looked like there was a plug, but the new bulb didnt have holes in the middle for the plug like the old plug, would it slide in?
Old Sep 18, 2009 | 11:59 AM
nogoodname's Avatar
nogoodname
yes, it slides in...... you clearly didnt even bother looking at my DIY
thanks solis
Old Sep 18, 2009 | 12:00 PM
SOLISIMO's Avatar
SOLISIMO
I just did, lol Ill try again when I get home
Old Sep 18, 2009 | 12:01 PM
  #29
lakers8's Avatar
lakers8
Yes it will fit for the reverse lights, it fit for me...
  #30
jnguyen's Avatar
jnguyen
