Is it normal that there is water condensation in headlight for a new 09 G37x...?
Old Jun 2, 2009 | 09:28 AM
njchen24's Avatar
njchen24
Greetings:
Finally, I just took a delivery of a new 09 G37x yesterday. The outside was spotless with no paint nicks or chips anywhere. The interior was decently clean but not spotless. There are some unclean areas, door panel and the overhead hand holders. At the last minute before driving the car away from the dealer, I notice that there are water condensation inside both headlight lenses in the same area as shown below but disappear overnight. I show them to the sale rep and take the car anyway since this is my second delivery (I refuse the 1st one due to a paint chip in the driver side edge door) and I don't want to give the sale person a hard time. He was extremely nice and worked out with me in all aspects and my demands.
This car like the 1st one has some black stuff on the rim. I have been told that it is for protection and will go away after a few wash.
Is it normal that the headlight has water condensation? Have anyone seen this black stuff on the rim when you pick your car up?
How come the manufacture date is 08/08 and it is an 09 model? That's probably explain the $31.5k price tag while other dealer are $1k to $2k more.
Thanks in advance for your comments and inputs.
Old Jun 2, 2009 | 10:58 AM
HamstersG's Avatar
HamstersG
Have not seen the black stuff on the rims. Mine are perfect. Should not be that way. Also, the lights should not have moisture in them. They should replace under warranty since they are new and have not been opened for customization......talk to service.
Old Jun 2, 2009 | 11:07 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Condensation in the lights is not normal. Take it back if it happens again. My rims didn't have any black stuff on them either.
Many 09's were built in 08. Most of the time model years are released in the Summer/ Fall of the previous year. Just like many '08s were built in 07. I took delivery of my 2008 in early Oct 2007. It was built in late Sept 2007.
Old Jun 2, 2009 | 04:29 PM
G37xS's Avatar
G37xS
There should be no condensation and ask them to detail the car properly that includes cleaning the rims.
Old Jun 2, 2009 | 05:05 PM
sebounet's Avatar
sebounet
Condensation in headlight is normal , i saw a TSB for that, when you wash the car with high pressure and also a difference in temperature between water and cars temperature it could happen, it should dissapear quickly (few hours)
I had the same problem and found this tsb
APPLIED VEHICLES: 2001-2009 Infiniti, All Models
SERVICE INFORMATION:
Occasionally customers may notice water in the exterior lamps. This is generally NOT due to a defect.
The following information, illustrations, and flow chart are provided to help you in determining if this incident for
water/condensation in lamps is normal or not.
All current exterior lamp assemblies are vented to the atmosphere (not sealed).
• This is necessary to allow for expansion and contraction of air from temperature "variations" (warmer or
colder) without damage to the lamp.
• Moisture in the air sometimes "travels" into and out of the lamp assembly through these vents.
• Certain environmental conditions may cause moisture to condense.
• The fogging/cloudiness should disappear over time when the lamp is in a dry environment.
If the moisture trickles, drips, or pools, it may not be considered normal and the headlamp assembly may have
a water leak path.
Old Jun 2, 2009 | 11:09 PM
da mayor's Avatar
da mayor
if it keeps happening, bring it back to the dealer. 8/08 is the production month your car was built
Old Jun 3, 2009 | 12:58 AM
PeterUbers's Avatar
PeterUbers
Does that black speckling wipe off at all? Almost reminds me of fresh brake dust on a recently waxed or polished rim --
Old Jun 3, 2009 | 07:55 PM
njchen24's Avatar
njchen24
Thank you all for your input and advices.
Special thanks for the TSB. Effectively, the water condensation happened after they wash the car thoroughly and the temperature has dropped a couple degrees in the evening around 6~7 pm.
Do you mind to share where you get the TSB from? I would like to take a look at the chart mentioned in the TSB.
One thing solved. Now the black stuff on the rim, I haven't tried any product to remove it yet. But I can't removed them with either my finger nails or by rubbing my finger over it.
a water leak path.
Old Jun 3, 2009 | 09:51 PM
sebounet's Avatar
sebounet
here you'll find the tsb, you need to register to read it, it's free, but you could download only 2 per days , if i remenber
http://x.infinitihelp.com/forum/loca...d&pp=12&page=2
Old Jun 7, 2009 | 08:12 AM
njchen24's Avatar
njchen24
Thank you much for the link.
Old Jun 7, 2009 | 10:05 AM
Falker11's Avatar
Falker11
How can one find out the build date of their car?
Old Jun 7, 2009 | 06:03 PM
KAHBOOM's Avatar
KAHBOOM
It's on a sticker in the door jamb
vamarris
Dec 9, 2018 11:10 AM
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
faze2988
Oct 7, 2015 12:05 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Bennyjoel
Sep 30, 2015 11:56 PM
