Would these LEDS work?
Old May 8, 2009 | 02:12 PM
jsingh's Avatar
jsingh
As the title states, would either of these LED's work in the parking light housing?
25 LED http://cgi.ebay.com/2pcs-T10-168-194...713.m153.l1262
http://cgi.ebay.com/ebaymotors/2pcs-...5412QQtcZphoto
I currently have the ijdm's T10's, however they dont seem to spread the light very much and not very bright at all. I understand alot of people are againt LED's in the headlight housing but these are relatively inexpensive and a few user on this board have bought from this vendor before and have been pleased with the service & product.
Thanks guys, let me know which one seems like a better option.
Old May 8, 2009 | 03:38 PM
OGtripleOG37's Avatar
OGtripleOG37
yes they do work. i have the amber ones on mine. peep:
Old May 8, 2009 | 03:43 PM
jsingh's Avatar
jsingh
^Done deal, you and STOOF have me convinced, ordered the 5's in white. Thanks.
Old May 8, 2009 | 03:45 PM
STOOF's Avatar
STOOF
From the looks of it OGtripleOG37 has the 25led.
Old May 8, 2009 | 03:55 PM
jsingh's Avatar
jsingh
^I can't tell, I'm at work can't see these pics. Do they look brighter than the 5's? LOL
STOOF would you ming e-mailing me these, lol.
Old May 8, 2009 | 06:31 PM
jsingh's Avatar
jsingh
I ordered the 25's aswell http://superlumination.com/images/au..._smt3_w_wm.jpg
Along with these for the H1's http://superlumination.com/images/au...36led_w_wm.jpg
I just hope the H1's fit?
Old May 8, 2009 | 07:07 PM
OGtripleOG37
nice....post some pics when ur all done. i def wanna see how the h1's look. i may also change to white instead of ambers if they look good.
Old May 8, 2009 | 07:15 PM
jsingh's Avatar
jsingh
^Def. Will do, Should look nice white and bright hopefully
I'm not too concerned about light output, going for the look more than anything else.
Total of 61 LED's, anyone know of any possible problems that may ocur with this, lol or is it all good to go?
A reg H1 bulb dimension
I've seen the vled H1 36 led and thats 24mm tall w/o the metal base. If this is anything the same that means I could be looking at 49mm tall, is that able to fit?
^Update: They are 65mm x 20mm, which I think includes top to bottom, buy I dont think they have a chance in hell of fitting
Old May 8, 2009 | 11:28 PM
jsingh's Avatar
jsingh
So if somebody could help me out. I've had to cancel the order for the H1s b/c they wont fit (36 LED). I've come across these 25LED H1's
If anyone could tell me if they would fit, that would be great.
Stock bulb
Old May 9, 2009 | 12:52 AM
bunluvsvw's Avatar
bunluvsvw
the led H1s are not going to be bright, you should have done hid, even Hids are not that bright nowadays. I think Im getting use to them, but I also have the 25 led citylights too, I suggest putting some black dummy on the base before you try installing them, it holds the light in real well and wont fall off if you move it around.
Old May 9, 2009 | 10:03 AM
jsingh's Avatar
jsingh
Which H1 LED's do you have, which are able to fit the housing with no difficulty?
I think I may have found my solution:
http://store.ijdmtoy.com/Hyper-Flux-...p/led_flux.htm
Anyone used or heard anything about these, they are advertised as for the G35/G37?
stealth210
General Tech Questions
27
Jul 26, 2017 06:48 PM
warpeacelove
Oct 28, 2015 02:59 AM
ZachThomas
Sep 3, 2015 01:40 PM
dlc1988
Sep 2, 2015 09:40 AM
