Regarding your grill paint
Old Apr 8, 2009 | 10:40 PM
SL1CKZ's Avatar
SL1CKZ
I want to black our my grill, but does anyone know what is a good paint I can use after I sand it down? Thanks
Old Apr 9, 2009 | 12:06 AM
finagle69's Avatar
finagle69
Duplicolor or Krylon if you want to DIY.
Old Apr 9, 2009 | 12:16 AM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
Wouldn't powder coating be better?
Old Apr 9, 2009 | 04:55 AM
SL1CKZ's Avatar
SL1CKZ
I want it glossy
Old Apr 9, 2009 | 09:00 AM
pfizzle's Avatar
pfizzle
Negative.
Old Apr 9, 2009 | 10:14 AM
JuztaJ's Avatar
JuztaJ
Originally Posted by SL1CKZ
I want it glossy
not a problem.. first sand it down, 2nd primer a few coats, 3rd duplicolor black gloss a few coats, 4th duplicolor clearcoat. Someone correct me if im wrong..
Old Apr 9, 2009 | 10:33 AM
InjectedPerf's Avatar
InjectedPerf
Exactly the way I did mine, except with a semi-gloss. Been through ice, snow, sun, 6 months now and still looks good.
Old Apr 9, 2009 | 10:48 AM
lakers8's Avatar
lakers8
you cant powdercoat plastic
Old Apr 9, 2009 | 11:17 AM
Heat's Avatar
Heat
You do that and let us know how it turns out!
Old Apr 9, 2009 | 11:57 AM
XMMAN's Avatar
XMMAN
and for those of us who want to go flat?...also what should you sand down the grill with?
Old Apr 9, 2009 | 12:21 PM
ucla bruin's Avatar
ucla bruin
lol @ the fail pic.
Sand it down with sand paper, I forget what grit rating but you need to have patience and dedicate an afternoon to doing this. Use automotive spray paint if you want to DIY. The surface is not going to come out with a really good shine or be very smooth though, if you DIY. Since you want glossy black, not flat, I'd recommend getting it sprayed at a shop so the surface can be really smooth to bring out the shine.
__________________
Old Apr 9, 2009 | 12:26 PM
chasemyaccord's Avatar
chasemyaccord
lol, great pic.
Old Apr 9, 2009 | 11:53 PM
JuztaJ's Avatar
JuztaJ
why would you say that?
Old Apr 10, 2009 | 01:55 AM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
ucla bruin is right, if you want that shiny finish take it to a professional painter. Should only be 50 dollars.
Old Apr 10, 2009 | 02:23 AM
ucla bruin's Avatar
ucla bruin
Because I have done it myself and then had it done by a shop a few months later.
The difference lies in the paint and even spray. Spray can won't be as consistent as a spray gun. Shop will most likely shoot the part at a clean booth too to minimize contaminants from landing on your grill while it's being sprayed. But the biggest thing is that shop paint is a lot higher in quality than the automotive spray cans.
Most of us that DIY do it in flat black, so spray can is fine. But if you want glossy so it looks like OB, I'd get it done at a shop.
__________________
