Carbon Fiber Mod for Impul Rear Valence
Old Dec 5, 2008 | 08:27 PM
SkylineV36's Avatar
SkylineV36
I ordered some real carbon fiber film from slymachines.com and applied the overlay over my Impul rear valance.
Quality of the carbon fiber sheet: Excellent, cuts very easily with a good sissor or blade. It is UV coated and seems very durable enough to put around my exhaust outlets. My paint around the exhaust was starting to discolor from the heat, so I decided to apply the film completely around the exhaust outlet. Had to take off my HKS tips, which was simple enough. The adhesive is 3M automotive glue, so you get once chance at the application stage.
Installation:
Comes with matching tracer sheet, which is basically a clear strip of plastic with light glue so you can you stick on the area as a tracer sheet, trace, peel off and apply to the carbon fiber sheet and cut. It bends around slight curves, but too firm for big angles or curved areas.
Enjoy the pics!
Old Dec 5, 2008 | 09:33 PM
Stanced370Z's Avatar
Stanced370Z
the idea is good but the cuts look horrible on it. :/
Old Dec 5, 2008 | 09:59 PM
DrJones's Avatar
DrJones
yep
Old Dec 5, 2008 | 10:22 PM
vinnys coupe's Avatar
vinnys coupe
not diggin it, maybe from far, but def not close up
Old Dec 5, 2008 | 10:55 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
what material is the rear lip... the paint doesnt look quite the same....
Old Dec 6, 2008 | 01:36 AM
da mayor's Avatar
da mayor
its different could use a bit of a clean up
Old Dec 6, 2008 | 01:49 AM
VRG37S's Avatar
VRG37S
I like the idea...Definitely giving you props for being different and trying something new and exciting....
Old Dec 6, 2008 | 02:02 AM
teedough's Avatar
teedough
where would i find that rear valence?
Old Dec 6, 2008 | 02:25 AM
aznutx's Avatar
aznutx
+1 on the idea/effort.. but gotta agree with the others. the cut isnt so great.
Old Dec 6, 2008 | 02:29 PM
SkylineV36's Avatar
SkylineV36
Thanks for the feedback guys, I'm not exactly the sticker dude. It does definitely look better from afar. The angle of the carbon fiber side is such that I had to take those picture lying on the ground. at standing or driving level, the not so perfect cuts are not as apparent. I'm happy with it.
The material is FRP or basically fiberglass. The paint match is very difficult on the Ivory Pearl, and had it painted twice.
You can buy the Impul kit from HP Autoworks or Bulletproof Automotive.
Old Dec 6, 2008 | 02:45 PM
SkylineV36's Avatar
SkylineV36
Here is a picture at a bit of a distance.
Old Dec 8, 2008 | 08:51 PM
SkylineV36's Avatar
SkylineV36
Fixed up the cuts with some matching touch paint and looks form fit now. Will post new pics later.
Old Dec 8, 2008 | 09:03 PM
jnguyen's Avatar
jnguyen
hmm like the idea but same with everyone else. does look pretty good though and that good you like it cause thats all that matter
Topher9425
Dec 1, 2015 03:00 PM
Rogue_G
Sep 17, 2015 09:44 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
1BADQ60S
Aug 10, 2015 11:10 AM
