FINALLY!!! STILLEN grille is now available!!!
Unfortunately we've found that color matching can be an issue, because the color of your car doesn't necessarily match the paint code, or any other vehicle supposedly the same color.
A quality shop will do a tremendously better job ensuring the part will match, especially when you consider the different areas being painted around that section, the hood, bumper, and this grille all being different materials.
So if we're painting parts to the color that's specified, and yours is slightly different, we're left with shipping parts out and back, refunds (which we would understand and do), or you're the nicest guy in the world and just deal with it, we still have what becomes and inferior product that looks horrible even in our own eyes, because the factory was just a titch different that day.
Ordered
Love the install notes
Installation Notes:
This grille does require some patience and might require some trial fits. There is adjustment built into the grille and we ask that the installer uses patience and takes their time to ensure a perfect fit.
Installation Notes:
Anytime you do any body work you want to be patient and be prepared to make some minor adjustments to the mounting locations. You won't need to do any grinding or cutting/trimming. But, you might find that you get close to perfect gaps on the first attempt and on the second attempt you can tighten those gaps up. It's pretty easy, but we want to let our customer's know that there is adjustment built in.
I apologize for not answering that question...I read it earlier and just forgot to answer it in my response.
The rear spoiler is also available right now.
http://www.stillen.com/product.asp?i...odel=G37%202DR
As well as the front lip.
And the roof wing.
And the roof wing.
