Signal Light
Old Aug 29, 2008 | 02:24 AM
Skyline-LEXY's Avatar
Skyline-LEXY
Signal Light
I read this on someones thread but I wasnt able to find that thread... So can someone please help. I just installed LED Super White front signal light, but it blinks too fast........ I heard you had to install something to stop doing that.. Does anyone know anything about this?
JY
Old Aug 29, 2008 | 02:49 AM
speedracer g37's Avatar
speedracer g37
you need to ad a resistor to the circuit.
Old Aug 29, 2008 | 02:55 AM
TerribleONE453's Avatar
TerribleONE453
where did you pick up your signal bulbs from?
Old Aug 29, 2008 | 12:04 PM
Dieseldoug22's Avatar
Dieseldoug22
I changed the rear turn signal lights to LED's and I added a 25 ohm resistor. There is a kit at Autozone that has 2 resistors in it and some scotch locks. It worked beautifully in my car.
Old Aug 29, 2008 | 01:43 PM
Skyline-LEXY
TerribleONE453 i got mine from ebay "motoringmax." ill post the picture. I got most of my LED from them. door, dorm, parking, trunk, and signal lights.
btw Dieseldoug22 was it hard to install them? could i use that 25 ohm resistor for front signal lights too?
JY
Old Aug 30, 2008 | 04:46 AM
Dieseldoug22
No it wasn't hard to install. The scotch locks it came with are easy to use. You just connect one end of the resistor to the positive and one to the ground. No cutting needed. Just finding a good place for them to stay was the hard part. The resistor is about 2" long by 3/4" square.
And yes, you should be able to use the same resistance resistor for the fronts too.
Old Aug 30, 2008 | 04:48 AM
ChOy BoY's Avatar
ChOy BoY
pics????
Old Sep 4, 2008 | 12:15 AM
Skyline-LEXY
^^ srry for the delay... couldnt find my camera........ FAIL on me I know...
I dont know if you noticed... I took out the side marker light bulbs....
cause those were the only yellow bulbs that were bothering me
NEXT HIDs........
pcwd
Sep 15, 2015 10:06 PM
B Feelgood
Sep 13, 2015 05:56 PM
