Exterior & Interior Light Specs/Sizes
Old Aug 27, 2009 | 12:38 AM
JKashat's Avatar
JKashat
Just ordered a bunch of lights from V-Leds.com and used a coupon code and got 15% off. Can't wait to get these and install them along w/ my IronMan v2.5 moded Carbon Fiber Headlights. Hope these are better than the Oracles that I also just bought off of eBay, LOL.
Old Aug 27, 2009 | 10:46 PM
VossenG37S's Avatar
VossenG37S
i went on vleds but wich ones do i get i need led's but see many options! im replacing door lights , map lights, plate, trunk=7 leds are they the 194's?
Old Aug 27, 2009 | 11:25 PM
JKashat's Avatar
JKashat
I got the turn signal, Fog Lights, DRL, Side Strip, Door, Map, Glove Box, Trunk, and License Plate Bulbs. $292.77, after 15% Coupon Discount> Basiclly, I got the high output most expensive version of every bulb, LOL.
Old Aug 27, 2009 | 11:35 PM
VossenG37S's Avatar
VossenG37S
so what is the led bulb i need for parking, map lights, doors, trunk, plate ...i see wedge bulbs and many others
Old Aug 27, 2009 | 11:39 PM
VossenG37S's Avatar
VossenG37S
where u get coupon ?
Old Sep 5, 2009 | 03:42 PM
JKashat's Avatar
JKashat
I just did a google search for v-leds coupon code and found one and tried it and it worked. 15% off for nothing, lol.
Old Sep 5, 2009 | 05:31 PM
nogoodname's Avatar
nogoodname
coupon, did someone say coupon ?????.............. just wait a week for a myg37 one
Old Sep 5, 2009 | 05:34 PM
SOLISIMO's Avatar
SOLISIMO
which is the brightest for the tag? Thats all I care about
Old Sep 5, 2009 | 06:58 PM
JKashat's Avatar
JKashat
Get the High Output Wedge that is the most expensive. Seriously.
Old Sep 5, 2009 | 06:59 PM
JKashat's Avatar
JKashat
I'll look at the receipt for my order and let you know later tonight.
Old Sep 5, 2009 | 10:01 PM
JKashat's Avatar
JKashat
I ordered the PIAA D2S 6600K bulbs and these are the V-LED.com bulbs I have ordered so far, and the discount code is "COMMANDER15".
Order Details
Image QTY SKU LOC. Description
1 H1_36_SMT_W V-LEDS HID WHITE 36 M-SMT DRL SHOW BULBS H1
WEIGHT: 0.05625 lbs
1 921_19_HP_W V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923
WEIGHT: 0.03125 lbs
1 7443_20_A 2 AMBER 7W HIGH POWER 20 LED PARKING/TURN SIGNAL BULBS 7443 7440
WEIGHT: 0.1 lbs
1 3175_2HP_W_6K V-LEDS 6K WHITE 1W HP LED DOME LIGHT BULB 3022 3021 DE3175
WEIGHT: 0.025 lbs
7 194_X5_HP_W 2 HID WHITE SMT X5 HIGH POWER LED LIGHT BULBS 194 168 158 2821
WEIGHT: 0.025 lbs
Coupon 'COMMANDER15': -49.41
Shipping: 8.79
Insurance: 4.00
Tax: 0.00
Order Total: 292.77
Old Sep 5, 2009 | 11:05 PM
Xcalibur's Avatar
Xcalibur
I highly recommend these for your liscence plate/door lights/map lights/trunk light:2 HID 6K WHITE SMT 5 LED LIGHT BULBS
The lighting on these spread out in all directions so they use the replacing refletors in your light housings and work well. I don't know about those hi-powered directional LEDs.
These are brighter but never tried: 2 HID WHITE SMT X5 HIGH POWER LED LIGHT BULBS
Order Details
WEIGHT: 0.05625 lbs
WEIGHT: 0.03125 lbs
WEIGHT: 0.1 lbs
WEIGHT: 0.025 lbs
WEIGHT: 0.025 lbs
Shipping: 8.79
Insurance: 4.00
Tax: 0.00
Order Total: 292.77
Wait a sec man I think you've jumped the gun. For instance those turn signal replacment LEDs may not fit because of bulb length and even if they do you will need to wire in load resitors or your turn signal will strobe like hell. Resistors are here: Load Resistors
There is a tutorial on installing LED turn signals around here. Thats one of my future mods for sure! Good luck!
Old Sep 5, 2009 | 11:10 PM
JKashat's Avatar
JKashat
Originally Posted by Xcalibur
I highly recommend these for your liscence plate/door lights/map lights/trunk light:2 HID 6K WHITE SMT 5 LED LIGHT BULBS 194 168 158 2821
the lightnig on these spread out in all directions so they use the replacing refletors in your light housings and work well. I don't know about those hi-powered directional LEDs.
I was wondering about those Turn Signal resistors. I haven't got my headlights back from Igor so I haven't done the turn signal bulbs yet. Am I going to need those for sure? I thought I might but hadn't heard anyone mention using/needing them. Will I need 1 or two or these for the front and rears? And, how do I know if I need the 3 ohm or 6 ohm resistors?
Old Sep 6, 2009 | 02:17 PM
  #29
Xcalibur's Avatar
Xcalibur
^^^ Yes from what I've read in the forum you will need it. You will need one per side so in all for front and back thats 4 you'll need.
Ask IGOR. Since hes an electrical expert he should tell you that. Also the resitors from what I know get real hot so you need to place them away from the LEDs.
Guys stop cuting your wires! Use Tap Connectors.
Old Sep 6, 2009 | 08:11 PM
  #30
g37vanbc's Avatar
g37vanbc
WEIGHT: 0.05625 lbs
I ordered this long time ago and they won't fit thru the opening in our headlights. (the round part is bigger then a regular H1 bulb) just a FYI
