Why have a keyhole with Intelligent Key... Oh wait I don't
Old Oct 19, 2007 | 12:55 PM
shumby's Avatar
shumby
how much? $$$
Old Oct 19, 2007 | 12:58 PM
Flyingcesar's Avatar
Flyingcesar
Jason told me $30 shipped for states out of Cali.
Old Oct 19, 2007 | 12:59 PM
Flyingcesar
How do you remove the old cover with the keyhole?
Old Oct 19, 2007 | 01:42 PM
peterbanks's Avatar
peterbanks
Originally Posted by RedHerring
Probably good for a solid 10 ponies ATW.
That's probably a low estimate...
Old Oct 19, 2007 | 01:49 PM
chilibowl's Avatar
chilibowl
For sure it is, Motor Trend did a review on this mod, they got 15RWHP and 40RWTQ
Old Oct 19, 2007 | 02:25 PM
peterbanks's Avatar
peterbanks
*I take ZERO responsibility if you **** up your car following these directions*
Lock your door.
Pull the door handle as if you were going to open it, then put a rolled up towel in-between the handle and the door to keep it open.
Then using the pic below as reference, use a small flathead screwdriver or what ever you have that is able to get into the space to lift the tab up. As you are lifting the tab, pull on the cover to remove it.
When you receive the part it comes attached to the mounting plate. See pic below. You are going to have to follow the same procedure to remove it from the mounting plate as you will when you take it off the car. This will give you an understanding of what you need to do on the car to remove it.
Old Oct 19, 2007 | 04:00 PM
carman63's Avatar
carman63
I guess I better put my order in soon!
Old Oct 19, 2007 | 05:03 PM
RedHerring's Avatar
RedHerring
Looks pretty easy to do. Thanks for the pics! They help a lot.
Old Oct 19, 2007 | 05:39 PM
UNV-IT46's Avatar
UNV-IT46
for sure going to order one. I dont see why you cant order this from any dealer...
Old Oct 19, 2007 | 05:41 PM
Flyingcesar
Thanks for the piks above… I just ordered mine and it will ship on Tuesday has they are currently out of stock till then.
Old Oct 19, 2007 | 07:25 PM
Wicked_limitz's Avatar
Wicked_limitz
yeah defin. a nice cheap mod! i did it on my G35 and it cost me about $20 bucks from the dealer.
Old Oct 20, 2007 | 10:35 AM
IP37's Avatar
IP37
that part number wouldn't be color specific would it?
Old Oct 20, 2007 | 12:15 PM
peterbanks's Avatar
peterbanks
I fairly certain it is.
Old Oct 20, 2007 | 12:26 PM
  #29
IP37's Avatar
IP37
any clue what the IP part # would be?
Old Oct 20, 2007 | 12:29 PM
  #30
peterbanks's Avatar
peterbanks
Email Jason in post #1, he would know.
