YAW bypass switch a.k.a Drift Switch
Old Jan 22, 2025 | 12:48 PM
  #121
BULL's Avatar
BULL
Moderador
Originally Posted by projectpanda13
Yea, only the button part. I kept the original wiring I got from Bull.
I suspect the LED swap to white might have shortened the life of them.
Lighter colors usually run hotter, being that it was slightly larger than the amber one didnt help either but it doesnt surprise why this style comes either in amber or green.
Old Jan 22, 2025 | 12:50 PM
  #122
BULL's Avatar
BULL
Moderador
Still not making these guys.
I went ahead and took on an idea for a "fuel pump interruption/ kill switch" that came out really good and now I'm getting requests for that
The direction and motivation are still there just like many, the time is not.
Will continue to update.
Old Feb 15, 2025 | 08:24 AM
  #123
unkownG37's Avatar
unkownG37
Do you make some for 2008 g37 coupe auto ?
stock dif
if yes I would like to buy one
Old Feb 18, 2025 | 03:02 PM
  #124
BULL's Avatar
BULL
Moderador
Good news everyone. I'm starting to make these again.
Before I start taking orders is important folks READ before.
The kit will work best with 6 SPEED/ MANUAL TRANSMISSIONS
Automatic transmissions will completely disable the "LSD feel" since it uses the ABS to provide an electronically/mechanically assisted limited slip. The kit will let the differential do ALL of the work.
The kit will expose the health of your OEM LSD. "One wheel peels" will be indicative of a failing LSD which means you'll benefit more from not using one.
Contact me directly for orders.
Please list in the message if you want white or orange lighting, If you want center console mounting or lower dash mounting for the on/off switch.
Only have 10 spots available for G37 folks at $60 + shipping
I offer these for the 370z as well if you have one or want to recommend one.
Old Mar 7, 2025 | 01:44 PM
  #125
Meech01's Avatar
Meech01
Can you dm me?
can you dm me?
Old Mar 22, 2025 | 06:00 AM
  #126
Finfing376mt's Avatar
Finfing376mt
Would like to purchase for 2010 g37 6mt
pls message me on how to purchase one
Old Mar 23, 2025 | 11:17 AM
  #127
Finfing376mt
I received your message in my inbox but it won’t let me reply send me a message of another way to contact you
Old Mar 23, 2025 | 11:36 PM
  #128
BULL's Avatar
BULL
Moderador
Either get your post count up by commenting in a few threads or contact me through Instagram at What_wires.
Old Mar 28, 2025 | 08:31 PM
  #129
goldbug's Avatar
goldbug
@BULL Sent you a DM, count me down for one for my 6MT coupe. I’ll send you another dm with my PayPal to send an invoice. I’m ready for payment.
Really appreciate you putting these together again for the community. Looking forward to my next track day with this.
Edit- For anyone else curious who’s also tuned with ECUTek, a physical switch has to be used for the G37. Only the NISMO 370Z ROMs allow tuning to bypass it.
Old Jul 12, 2025 | 11:48 AM
  #130
Thatbravokevin's Avatar
Thatbravokevin
Hello everyone for those that don't know I wire things up in my spare time. The product I'm providing is a YAW sensor bypass/ Drift switch.
Z/Gs have a lateral gravity sensor called the YAW rate sensor. This particular sensor will interfere with the car's throttle during a heavy lateral Gs. Usually a heavy turn coming in fast, you'll see that even with VDC off the car will cut the throttle and the stability light will blink.
By doing some research you'll find that most people cut a wire to the sensor and place a switch inline to turn it on and off. Though this method works it involves cutting and drilling depending on the switch you choose.
I came up with a clean "plug and play" method which wont require any cutting nor drilling to install and can be easily removed if the owner wishes to re-sell the item or the car itself.
I created 2 types, one for the 370z and one for the G35/37 for both the 7at and 6mt.
For detail purposes I have to customize the switch for the G since my supplier only carries orange.
The differences in both are colors and placement of switch.
The Z uses the center console for switch placement
The G I went ahead and utilized one of the few blanks these cars offer and it's by the hood lever area.
Fully crimped harness covered in heatshrink as non invasive as possible.
LED on equals operational system.
LED off equals system disabled.
Just like the DIY bypass you'll have to cycle the key once you're done using the button.
Trying to make a plug and play electronic part budget friendly was a bit of a challenge but you dont have to do any permanent modifications to the vehicle by opting for this option.
The Z kit can be yours for $45 shipped in the US
The G will be at the same price ONLY FOR MYG37 members only. The G switch harness is 5 feet longer and includes a white LED ($55 normally) (Since most of you were the driving force behind this)
Anyways here are the pictures
I would like to purchase one for my 350z. Here is my email kevin77munoz@gmail.com
Old Sep 29, 2025 | 03:17 PM
  #131
fonarikmarik's Avatar
fonarikmarik
Are you still selling these?
I’d like to order one for a 6mt 2012 g37s sedan.
please email me: markloboda7@gmail.com
Old Oct 2, 2025 | 04:56 PM
  #132
rx794's Avatar
rx794
I PM'd you about me purchasing the switch for a G37 Sedan.
Old Oct 2, 2025 | 10:32 PM
  #133
fonarikmarik
I don’t see the PM, email me plz
Old Oct 2, 2025 | 11:48 PM
  #134
rx794's Avatar
rx794
Sorry, this wasn’t meant for you. My bad.
Old Oct 6, 2025 | 04:05 PM
  #135
rx794's Avatar
rx794
@BULL Are you still making these? I PM'd you.
