Alarm Blaring
Old Feb 27, 2020 | 12:09 PM
Burnyburn52's Avatar
Burnyburn52
Alarm Blaring
Ive onwed my 2013 x coupe for about 4 years now and never experienced this before. Apparently if you lock your G with the key fob and use the actual key part to unlock the door manually, it will set off the alarm...? Thought it was kind of funny as I was at a shop and had to walk inside to get the key fob to stop the alarm even after manually locking it back up... Weird, but possibly expect the same results if you do as I do. Not sure if this is in the wrong section or has been reported before but figured I'd share a weird experience ive had with my G.
Thanks guy's
Old Feb 27, 2020 | 04:00 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Burnyburn52
...Thought it was kind of funny as I was at a shop and had to walk inside to get the key fob to stop the alarm even after manually locking it back up...
Thanks guy's
Might make for a funny "ha ha" moment, but that is not normally how NATS/IVIS works. Unlocking the car either with the mechanical key, the door handle switch (w/fob in pocket) or with the key fob itself should turn off the "alarn."
Old Feb 27, 2020 | 04:18 PM
Burnyburn52
Might make for a funny "ha ha" moment, but that is not normally how NATS/IVIS works. Unlocking the car either with the mechanical key or with the key fob should turn off the "alarn."
Thanks for the feedback. I didnt think it was out of the realm of possibility since it was originally locked with the keyfob, then unlocked with the key, while the keyfob itself was roughly 60 feet away. But assuming something is wrong, do you have any suggestions of what that could possibly be?
Old Feb 27, 2020 | 04:25 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Sixty feet away is quite a distance. I'd repeat with the key in your pocket, see if you get identical results. Normally the active part of the fob is only energized when near the car, or one of the buttons is pressed.
Old Feb 27, 2020 | 04:44 PM
ILM-NC G37S
With the fob in your pocket you should be able to press the door request switch to turn the alarm off. Regardless, whether you have the fob or not, you should be able to turn off the alarm with the m-key (mechanical key). Are you able to open/close the windows with the m-key?
The funny part to me is that you actually use/used the m-key. In all the years I've had this car I have never once used it- of course the key hole is covered to begin with, but...
Old Feb 28, 2020 | 06:41 PM
13_SkylineSedan's Avatar
13_SkylineSedan
As ILM... said, you should be able to lock or unlock your car using any of the 3 methods without setting off the alarm. The mechanical key portion of your i-Key has an embedded chip which is meant to be scanned by a small antenna near the door lock. The BCM reads that chip and disarms the alarm before you open the door. It sounds like in your case that didn't happen and your BCM took the open door switch signal as unauthorized.
To test further, you could try pulling the battery from the iKey and putting it in the "Intelligent Key Port" (with the mechanical key in it) on the driver's left side below the trunk release button. If you can't start the car like that then you will want to re-register that key's chip with your BCM. If you CAN start your car like that, then you need to diagnose why your door antenna isn't reading the chip correctly.
G_dirtyFrank
Jul 4, 2017 01:30 PM
folsomg37owner
Jan 23, 2015 04:26 PM
Creationx
Apr 16, 2014 01:02 PM
jhenka
Dec 10, 2010 11:19 AM
shoeyg37s
Jul 8, 2008 07:47 PM
