G37 Coupe, how much to spend for worthwhile speaker upgrade?
Nope, like Surfnazi said, go with 0 gauge feeds. There's ample room to run them direct from the battery to the trunk. Just make damn sure you use thick grommets when you feed the wire through a metal bulkhead and fuse the lead as close to the battery as possible
You have the tiny tweeter in the wedge between A pillar and door. Then next to the handle there is another small speaker, I think it’s like 3”. The JL 3-way C5 has the 6.5” for the bottom of the door, the tweeter for the wedge but then middle sized speaker in our car next to the door handle is too small I think to fit the mid component 4” speaker the JL comes with. If it does, then the JL (or another brand) 3-way component seems perfect for the front.
BMWkilla
Aug 25, 2008 01:57 PM
