Clock Current
Old Apr 23, 2018 | 08:35 PM
mtheengineer's Avatar
mtheengineer
Clock Current
Hello,
I am working on a side project, and need a little help. I bought a spare analog clock from a G body style. I have not studied the wiring harness, however, it appears that the connector only has 4 wires. 2 positive and negative i am assuming that power the clock, and 2 power and negative that i am assuming power the back light for the clock. My question is do these wires go straight to the battery? Is there any circuity in the clock that is current limiting? I would like to know if there is a max current the clock takes before i plug 12 volts to it and blow it up.
any feedback would be greatly appreciated.
Thanks,\
Old Apr 23, 2018 | 09:54 PM
GoodB0Y's Avatar
GoodB0Y
If no one has the answer...
I would suggest you look at the wiring diagram for the clock circuit... My guess would be that looking at the diagram will tell you what you need to know.
Old Apr 24, 2018 | 08:05 AM
mtheengineer
I agree the wiring diagram would be the ideal spot, however, i don't have that..i was hoping somebody would know...obviously i should take the safe route and put a resistor from the power source to the clock, however, i need to know what the working level current is so that i can pick out my resistor accordingly...
RudeG_v2.0
Apr 12, 2007 01:09 PM
chbak014
The M - Spot
Aug 29, 2006 09:03 AM
