Any chance you could post a pic of the display? Do you just select the Aux input to use it? Does it automatically connect the next time you start the car?
Thanks!
You have to be on the Sat mode. It you are on Sat mode when you turn on the car, it will connect automatically. A voice promt will say "connected". I use Google Music and it works great for me.
You've definitely made me interested. If you turn on the car without being in sat mode do you just have to connect bluetooth manually, or does it always connect with the car either way?
It will automatically connect. I only had to pair once. If i was listening to the radio and switch to streaming my phone, i just switch to sat and I'm connected.
If you have satelute subdscription, and you are streaming, you will have to switch to radio and switch back to sat to get to your sat channels. Does that make sense?
Yep, should arrive tomorrow it seems so I'll probably install this weekend.
it took me less than 30 minutes to install it. my strugle was trying to remove this white connection, my hand was too big. what i did was i unclipped the black clip to give me more space. i used a flathead screwdriver to push on the pin and gently pulled on the wires side to side.
