Button not working for Drivers door
Old Mar 20, 2018 | 03:56 PM
jeff82's Avatar
jeff82
Question Button not working for Drivers door
I've got a 2008 G37 with Upgraded package (Journey I think). First post on this site, I looked through the site and google but didn't really find a answer to this. When pressing the button to unlock the drivers door, the door does not unlock. I am able to walk over to the passenger side and unlock it fine with the button. I tried to replace the battery in the key FOB however that did not help. I was able to lock the FOB in the car a few weeks ago so maybe that's a indicator of a sensor issue. Not entirely sure how the car can tell if the FOB is in the car or not but I think it uses information from both the passenger and drivers door to semi-triangulate if it's present.
About to dig further into this, was wondering if anyone knows some common causes to the button on the drivers door not working properly.
Jeff
Old Mar 20, 2018 | 09:26 PM
saywat?'s Avatar
saywat?
well if the button is broken then its broken.
Old Mar 21, 2018 | 12:50 AM
slartibartfast's Avatar
slartibartfast
Yup, what ^^ he said.
Old Mar 21, 2018 | 03:58 AM
jeff82's Avatar
jeff82
Are you referring to the button not working mechanically?
Old Mar 21, 2018 | 04:45 AM
saywat?'s Avatar
saywat?
Mechanically or electronically but not magically. . Jus try replace it man jesus
Old Mar 21, 2018 | 09:39 AM
telcoman's Avatar
telcoman
Jeff
You've got a ten year old vehicle. The common cause is things begin to fail as vehicles age. You can expect more part failures if you want to keep a ten year old vehicle.
Test the button with your multimeter!
Telcoman
Old Mar 21, 2018 | 12:14 PM
slartibartfast
The driver door lock/unlock is THE most used button on the car. Expect it to fail at some point.
Old Mar 21, 2018 | 12:26 PM
NealP's Avatar
NealP
I experience this issue when using my car starter. Sometimes it works fine other times it doesn't. When it doesn't work I can usually move the fob closer to the front of the door by the steering wheel and it'll work. I suspect there's some signal interference as it's fine when I don't use my starter.
Sounds like you're having a different issue but thought I'd mention in case someone else stumbles across this thread.
Old Mar 21, 2018 | 02:29 PM
saywat?'s Avatar
saywat?
i love the button feature. im so happy infiniti made it standard back in 08. other cars still playing catch up in 2018 and some still dont even offer it standard. infiniti sure is cool sometimes.
Old Mar 21, 2018 | 06:21 PM
AdamBritt's Avatar
AdamBritt
I pretty much only use that to lock and unlock, might switch strictly to the fob now. At least they're less of a pain to fix/replace.
Old Mar 21, 2018 | 06:23 PM
saywat?'s Avatar
saywat?
^lol wat else would u use it for? but dont be afraid to use it man its pretty bullet proof i havent read much on here about it being an issue
Old Mar 21, 2018 | 08:58 PM
AdamBritt's Avatar
AdamBritt
I have PTSD from door handles. I'm currently trying to fix the one on my 944 Turbo and it's seriously stressing me out. I've done those handles before but just not having luck with this one.
Old Aug 21, 2021 | 05:20 PM
dzhem.ahmed's Avatar
dzhem.ahmed
Jeff
Hey, i just had the same issue, and was trying to find some answers. My passenger door was working and driver’s not. So i just tried entering the car and with the car running and the windows rolled down pressed and hold the button for couple of seconds which made a beeping sound and now it works fine. And decided to write this, may be it will help someone
Old Apr 28, 2023 | 12:16 PM
OG2T0N3's Avatar
OG2T0N3
Well this is a very old thread an I'm not fimiliar with forums in gerneral so I dont get it yet, was there an answer to this issue as of now because I'm having the same issue here - keyless entrey button not working on the drivers side door on a 2011 sedan I just picked up.
Thanks.
Old Sep 12, 2023 | 08:41 AM
Fman007's Avatar
Fman007
I know someone talked about buying one off of amazon and swapping it into our cars.
Amazon Amazon
The Review I just read on it.
5.0 out of 5 stars I REPLACED A NON WORKING 2015 INFINITI Q40 KEYLESS REMOTE EXTERIOR DOOR HANDLE BUTTON
Reviewed in the United States on July 18, 2023
Verified Purchase
I bought this handle and removed the keyless button to replace a dead one on a 2015 INFINITI Q40 (It is really just the last G37) This switch is not sold separately. Meaning Infiniti makes you buy the whole handle for $$$$$$!!!. I bet a lot of Nissan and Infiniti models use this same switch on different handles. Look at youtube for tutorials on removing handle and then remove and splice in new switch. Working great!
