Discovered some wires...
Old Nov 1, 2017 | 11:18 PM
CømplexMuch's Avatar
CømplexMuch
I was tidying up my trunk in my 2008 G37 base coupe and found wiring for a sub & amp set up just laying around. I traced the wires and they are all complete and live... If I were to simply connect an amp and subwoofer box to these, would I run into any issues? Not looking to add massive power, maybe just a 10 inch woofer with a 500w amp. I have all factory equipment at this time.
I also capped these live wires off for now because I do not want to short anything out.
Any help would be greatly appreciated
Old Nov 2, 2017 | 12:58 AM
Crazyirish's Avatar
Crazyirish
The only thing I would look at is quality and gauge of wire. I avoid CCA wire for car use (really any use) but its common to use because of cost. As far as gauge (thickness) here is a chart courtesy of crutchfield.com:
Was any of that what you were asking?
Old Nov 2, 2017 | 01:06 AM
CømplexMuch
It looks to be pretty standard wiring, likely cost effective wire kit. I will have replaced if need be, but connecting a small set up should cause no conflict to factory Bose equipment will it?
Old Nov 2, 2017 | 02:30 AM
Crazyirish's Avatar
Crazyirish
The power wiring shouldn't. Where the previous owner tapped the signal wiring will be relevant.
Old Nov 2, 2017 | 09:23 AM
blazeplacid's Avatar
blazeplacid
Post a pic. I can help you sort it out.
Car audio is my first love <3
