Slow USB Read
Microsoft They limited FAT32 to promote their NTFS I was able to format as FAT32 using command prompt CMD easily!!
DivX Converter was the first software I tried with no success. I tried a customized AVI format with 720x408 (maintaining aspect ratio) and MP3 audio with no success. What's the right sauce here?
Windows will not allow FAT32 formatting of higher capacity drives. I used a simple .exe utility I found online to format the 64gb stick to FAT32.
I use a application called DiVX Converter to convert video files to DiVX.
Both were free utilities I downloaded to my laptop and work fine.
I can not understand why DivX Converter would not work for you. Here are the settings I use:
Output Profile: Home Theater;
Custom Resolution: 720x420 (depending on the source file, the output resolution will be adjusted slightly by the converter);
I increase the Video Bitrate to just over 2000kbps;
I click START, let the converter do its thing and shortly thereafter I have a working .divx file. After that I copy it to the USB stick and call it a day. I have had no playback issues to date.
